HomeLink Buttons question
Do those buttons work with commercial openners, like the ones in my condo building? I have a fob thing for the parkade that has a couple of buttons on it for openning different doors, but I didn't seem to be able to program them to work with Homelink during one quick attempt.
Has anyone done this?
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
i know, i know
I tried again today - no good. I guess the remote codes used in my building are outside of the range for the homelink. Too bad, would be quite convenient.
Sweet - Thank you guys - I had just filed it under the car was broken since the 1st owner never got the code to program, but I just got it done.
THANKS - I had to press the button on my "Overhead door" after the fog lights flashed - then held down the desired button inside a couple of times -
Cheers -
GS
Cheers -
GS
I couldn't get mine to work the first two times I tried. I called Homelink and they suggested changing the batteries in the handheld remote. I was very skeptical, but changed the batteries and it worked first time.
Makes sense.. the homelink reciever in the car that is trying to learn your code may want a nice, clear and strong signal to learn. The weaker one may be enough to open the garage.. the garage door trusts the remote already.... but the car is learning what your remote code is and wants to get it right.. .not the crosstalk from the neighbor.
