Please tell me that I’m not the only one…….
Who has overfilled their gas tank and had fuel go all over the side of he car and down the drain plug. I was so embarrassed I haven’t done anything like that since I was a teenager. My only solace was that I had waxed my car recently and had a micro fiber towel handy to clean the mess up on the side of the car. But that’s what I get for trying to top off the tank when there is the vent trap on the pump………
So, once in a while, more frequently than I would like and more frequently than with my other car (Boxster) in trying to fill up tank after a too sensitive nozzle has shut off prematurely I've overfilled the tank a couple of times. Not enough to run fuel down painted fender surface but to get a bit of fuel spillage that wets the basin around the bottom side of the filler tube.
My technique is getting better though. I let nozzle shut off and note by the pump amount whether there's more room in the tank -- getting better at noting how much fuel tank should accept by gage gas needle position -- and if I belive there is more room in the tank I manually begin filling the tank until the nozzle shuts off again. I have to hold the the nozzle just so so as not to trigger an early shut off again but when the nozzle shuts off I don't try to add any more fuel.
Sincerely,
Macster.
idk about you, but our tanks are 16.9 and when it says 0 about 2 left.. when i fill up to the "click" i get about 14.7 so that means im leaving about .2 out of the equation.. that .2 or... 4 miles i could really care less about for the extra hassle and annoyance of the "clicks" to fill and the embarrassment of being the guy that overfilled his tank and now smells like gas.
i will say the best feeling ever is when you fill up your 997.2 and you jump back on the highway and your "miles to empty" is ABOVE 500! not even civic owners can say that!
I found that certain pumps did this on my 997. Those that have the vaccuum seal (like all in CA do) seem to catch the vapor pressure and shut off correctly.
It's happened to me a couple of times - seems to be related to the angle of insertion of the nozzle.
No biggie - does help to have some Griots spray carnuba and a cloth.
I have never done it on the car before, as like Minok, I walk away once the auto-shutoff happens. However, if it makes you feel better, I did it the other day on my Harley, as I "just had to get taht extra squeeze of gas in there."....doh! It suck,ed and worst part, stank the whole ride home Luckily, no damage to the paint
Never over-filled, but I occasionally get the dribbles - so I got one of these; a real OCD kinda thing
http://www.griotsgarage.com/product/...s/fuelguard.do
