RMS / Oil leaks covered by CPO?
Thanks for all the help fellas. It sounds like the seal they will replace it with is better, who knows.
Agreed, but thinking as I have it open I can maybe avoid the labor cost and just pay for parts.
Just trying to prolong or avoid the labor costs of the future.
Having said all that, if they open it and the clutch and pressure plate are socked with oil they may have to. Who knows.
The CPO does exclude damage from track or racing events, FYI
RMS oil leaks Porsche does not admit to
I have a 2005 C2 997 at 31K miles Porsche replaced the RMA and IMS seals both were leaking. Now at 38k miles they are gone again. Repair estimate $1700.
I complained to Porsche and they told me to take it to a deal to get it verified. I did. I called them they told me I had to go back to the dealer and have the engine and trany dropped to properly verify it at my cost. So they must think I am an idiot. They want me to pay for the majority of the repair, the labor and they give me the seals worth about a couple of hundred tops.
Sounds to me as a class action suite is need to get Porsche attention on their problem
My understanding is the the clutch assembly for the 6MT ( which is heavy) sits far from the closest bearing which is where the RMS is. This extra weight evidently can cause the bearing case to drift downward relative to block(s) causing it to be unaligned with the shaft.
Well guys my local shop has confirmed that it is infact a RMS. I called my Porsche Dealer Napleton Porsche in Westmont Il and they do cover it under the CPO!
So off it goes to the doctor while I leave on vacation for 2 weeks.
Question 2=> Is this an opportunity to try to get a new clutch, whether they cover it or not?
uninformed gas bag
(contemplating on whether gas bag is one or two words)
While the clutch likely would not be covered under warranty, if it were me and I was tracking the car and had the cashola to cover it I would put in an LWFW and a high performance clutch. They're already in there and have to pull the clutch and FW to get to the RMS so you'd should only be on the hook for the parts.
Probably true and an understandable position, imo. Even though Porsches are designed to be driven hard, a car that is raced or driven extremely hard is more likely to have problems than a car that is driven in the normal course on the street. Porsche can choose the conditions under which it stands behind its cars. That being said, how would they ever know if the car had been on the track? Other than a ton of overrevs or some obvious racing modifications, I don't see how they'd know, unless you voluntarily told them.
