My 997.2 engine difficult to start
sorry for the delay to the OP... drove my car to beach house and been there last 2 days so havent been able to reply.. car started fine 5x in row now.. maybe mine was just a fluke.. hopefully yours was a fluke as well.. wish you the best of luck, HPFP does NOT sound like fun.
Drove the car today (Sunday) as well, and the car started up fine without any problems. So...still can't decide whether to take it in. I will probably call up the service advisor and asked for opinion, since if I can't reproduce it, how would they diagnose this problem? I don't think a fault code has been written?
Although going to limp mode is no fun, either, I would like to give a bit more evidence to the service advisor.
I called my friend at Porsche Orlando which is a great no
nonsense dealer. He said not one car has come in yet with hpfp issue an one lazy start could be anything including maybe some weak fuel. Said keep an eye on it and let him know. He said if I were to get a few in a row then worry and call for tow
on them. Otherwise no worries.
I'm not going to take it in till more issues
This is the same problem I had with my BMW 335i convertible. Long long starts, finally the HPFP died, and they replaced it the next day with a new one, happened last month. Fixed the problem instantly. It's a known problem with DFI engines.
Called the dealer today, admit that I have no problem for 3 straight days, and he advised that another fresh tank of gas and see what happens, since it's hard to diagnose a problem without seeing it directly. Keep my fingers crossed.
Bad news...I found I am having trouble revving the engine above 4500rpm. I ran into this problem 3 times already, and in each instance I thought PDK was slipping, so the engine hesitated. Then I realize that my PDK is so new that it should not slip, and it could be caused by the fuel pump struggling to deliver fuel, therefore I am feeling the engineer stuttering. When I let off the gas, it's fine again.
Definitely I am going to take the car to the dealer.
What would be nice to know is when the engine takes unusually long to crank is there a fault or code stored so the dealer could diagnose it then? It would be better than having to wait for the limp home mode or in my car the reduced engine power warning which as others have noted could occur at the wrong place at the wrong time.
Sorry to hear, if it is the HPFP then they order the parts and perform the repair.
What would be nice to know is when the engine takes unusually wrong to crank is there a fault or code stored so the dealer could diagnose it then? It would be better than having to wait for the limp home mode or in my car the reduced engine power warning which as others have noted could occur at the wrong place at the wrong time.
Now my car is fine in normal driving, but I do not want to push my luck and get into the limp mode. Since I ran into hesitation above 4500rpm 3 times already, I could just tell them to try it.
What worries me is the shortage of HPFP...i don't think my dealer gives out Porsche loaners. I have a Saturn SUV last time.
True, there's no check engine light, so I assume no fault code has been recorded. I asked the dealer about this and they agree.
I hope your dealer diagnoses it fast, has or can get the parts quickly and gets you back on the road in a day or two.
