Disappointing News
Disappointing News
Hope this isn't a trend! After 4 days of ownership my PCM is not turning on as usual. It is supposed to be active all the time except when manually turned off. It worked great for 3 days. I went to my local dealer and when hooked up to the porsche code reader it said my car had at one time low or insufficient voltage, there were faults all over the place. Maybe common for a car sitting on the lot waiting to be sold. Seems like the selling dealer would have checked the codes and cleared them. It's called a "handover" so the new owner has a clear start. In any case the local dealer cleared the codes and tested the battery. After a short rest the PCM is completely inoperable, no radio, phone, nada, perfect! Now the message says "system fault, see workshop". Every now and then the tach needle jumps and all the warning lights blink And for those interested, the iPod cable does not seem to charge the iPod. Crap.
Why would the dealer check the codes and clear them? You bought a brand new car, right?
Sounds like you've some kind of defect in your PCM. (duhh!!) Try and be patient and stay on dealer 'til fixed.
Edgy01 (see above) just had his PCM replaced under warranty recently. Hang in there. Porsche will take care of this.
Phil
p.s. Dan (Edgy), go to 993 forum and check out "Nice new addition @ RPM" thread. I think you'll like what you see!! I know I did.
p.s.s. Still need to set up central coast get together!
Cheers,
Phil
Phil
Cheers,
Phil
