Neither my car or 997.2 Maintenence Book has it, although there is a space for it
Check all your books - sometimes it's on a loose piece of paper and the dealers forget to pull it off and stick in the maintenance book - that's where I found mine.
Post the Vin number you're looking at and I'll print you the pro forma from the Porsche system. The sticker which your dealer should have put in the book comes detached and in the glove box.
Hey there kindlydo it for me, is for my 2005 Carrera 2S. Thanks in advance.
I’ve heard that the placement of the sticker on the underside of the bonnet was optional. Some dealers did it, some didn’t. As mentioned above, if it’s not on the underside of the bonnet, then it should be in the maintenance book.
