Please Help..underhood cable damage
So I pull over, open the front trunk, removed the cover from over the battery compartment (thinking there NAV CD player was down in there), and come eye to eye with the problem.
Chewed cables.
Mouse Porsche buffet.
Such a young and innocent 997.2. Only a baby really. It just didn't seem fair
Anyhow, first off the new 997's don't use a CD for the NAV, all the info is on a hard disk. Second my cowling area was full of wall insulation, seeds and mouse excrement. And several mice. Looking at me.
I drove to the dealer and they told me to drive back to the car wash and vacuum all that crap out of there. Which I did. And drove back, and they commiserated with me as we looked over the area.
As this was Saturday they suggested I come back Monday.
Today I got up and decided to tackle the repair myself and removed the wper arms, battery, plastic cowling.
Interesting tidbit- Porsche incorporates the NAV sat antenna and radio antenna into the cowling under the windshield! That is friggen cool as hell engineering if you ask me.
Sad results: The mice ate through the outer woven wire of the coax for the SAT antenna and the cabin air filter is full of mouse refuse.
Any forum members that are electronic wiz kids and can tell me if the coax can be repaired via splicing? Or maybe patching in two connectors so as to remove the damaged area? The inner conductor is unscathed, just about 1.5" of woven outer wire is chewed through.
I hate to consider buying and routing a new wire, but I suppose I would just run it outside of the harness from the PCM to the cowl antenna. And leave the main wiring loom alone.
Pics attached for your vicarious viewing pleasure.
The garage now has 14 mouse traps of three different designs. An suggestions how else to avoid this in the future?
Last edited by ltc; Jul 19, 2009 at 07:53 PM. Reason: edited title, removed cancer reference - ltc
Apparently like many forum members you removed your cats. I recommend replacing those to chase away the mice.
If this is the case, and since there is adequate braided shield available at both ends of the damage, you can try this simple repair procedure.
1. Straighten the cable and verify that the center conductor is NOT showing thru, in other words, no dielectric has been chewed.
2. Purchase some copper tape (available online from various electronics supply websites/shops). It comes in various widths, I would suggest 1/4" or so, no larger than 1/2". This tape has a conductive adhesive on the backside.
http://search.digikey.com/scripts/Dk...ame=3M1181A-ND
3. Beginning at one end of the cable, wrap the copper tape 1-2 times around the exposed braid (shield/outer conductor), then slowly spiral wrap the copper tape, overlapping to make sure the dielectric is 100% covered until you reach the other end.
4. Wrap the copper tape 1-2 times around this end of the exposed braid/shield conductor. Cut the copper tape.
5. Wrap the entire cable assembly (in a spiral fashion) with 3M Scotchlock electrical tape (available at Home Depot, etc). This is premium grade electrical tape, not the cheap generic. Make sure you completely cover the copper tape. You may wrap it 1-2 times, no more is necessary.
From an electrical (impedance) perspective, this repair should not affect the operation of the system and does not require cutting and installing a new FAKRA connector...and an extention FAKRA cable.
Simple to try, very inexpensive.
also, good stuff in your post, thank you very much! I am going to try that copper tape.
MJones- foil to keep the whiskered, beady eyed ones from nesting down in the cabin air intake plenum while I effect repairs :-) Didn't know anything else to use that the little bastards wouldn't eat or remove in the meantime.
Edgy- lol. Very funny! :-) Yes it is a first for me for rodent damage.
Adias- I, and my car, moved into a new house in March. It has a garage. My 997 lives in the garage. I drive my 997 2-3 days per week.
Will someone be kind enough to post a list of the various health maladies that may not be joked around with? Prostatitis? Aneurysm? Cauliflower ear? Gosh folks, no harm meant on this side. I just thought being eaten from the inside, as my car was, was analogous to the health condition of which we should not speak. No ill will or callousness intended.
Peace!
Is there a chance it has been there for a while and yoy have not noticed it? or it did it happen within days of your noticing it?
If I were you, I would call a professional pest control company to take care of this. The stuff consumers buy is not good enough, I'm told.
