Is the 6 speed really as good as PDK
#31
Softness and precision from a human interface perspective does not mean a tranny is better than another in my view. To me a good tranny is one whose shifts are positive/solid and well determined - Porsche's ZF or Aisin are. Smooth as better shifts a la BMW or Honda are not what I'm after.
I don't know about that... you've never seen how I shift
#32
I though I would jot down an observation today and see if it rings true to any other 997.2 stick shift drivers. This might have been the day i realize I need to have this checked in detail by a tech.
I was coming off of a nice exit ramp doign about 55 mph. I drop the car into third, and then to second. The car wouldn't shift to 2nd. And went it did click into 2nd, it was accompanied by a large sound I can only describe as a boom and bang sound. Not loud. More like the sound resistance makes.
So I think I am very concerned. I mean I didn't ask the transmission to do anything crazy, just two simple down shifts.
I also know for sure now this transmission is not as smooth as the 2009 Boxster S I drove for a month. Does Porsche use the same transmission and clutch? If so, then I know for sure I need a tech to drive this one. Next week i will make my way back to the dealer. My hope is something can be adjusted so there is not so much resistance.
They say our clutch is self adjusting. Maybe it's the clutch that's doing this? I had two tail lights that were just defective and replaced. maybe the clutch is bad?
#33
I think the 6 speed gearbox in the 997s (mine is a .l) is the best of the numerous stick shift cars I have owned incl 5 BMWs. It may not be the perceived "smoothest" but it is has the best mechanicallly precise feel and excellent clutch action. It does get hung up going into first occasionally ..annoying but that's about all. Its also a bit stiff when cold so I dbl. clutch upshift till it warms up completely.
Break your car in a bit more and get "at one" with your gearbox. BMWs are smooth shifting but so are Hondas, Acuras, etc. When you have more time with your Porsche, you will love its gearbox/clutch.
PDK..have not driven it. I am sure its great but not for me at this point in my sports car.
#34
Received 2,871 Likes
Well, I've spent the last 2 days driving my fathers Selespeed Alfa 156. It took me a couple of hours driving to get used to it again but then as I drove into the garage this afternoon I did the classic and hit the "clutch". The car stopped quickly I can tell you!
Looking forward to getting back into my manual....!
#36
Yes, on of the joys I have is shifting from third to second on manually equiped cars when i am about to enter a slower speed corner. What happens is, the car slickly move to the lower gear, but it is abruptlly met with this hard resistance. Usually it's a thump or a bang. Some say it's inherent to the transmission. But it does not happen from 2nd to third, third to 4th ect...
Who knows, maybe there is just something wrong with my second gear. I thought it might be the clutch, but it may not be.
I have been drivign a stick shift since 1998. And have had many different cars up to this carrera. None have exhibited such a notchy second.
Should I be blippign the gas at the precise time I shift into second. usually I shift and a nano second later I am hitting the gas.
#37
When I down shift as I exit a slower speed corner, I usually blip the gas before I down shift. Try doing this even on a straight away. i rarely use the engine to slow the car. P-cars have such great brakes! I have paid more attention to my manual gear shift after reading your post. The 997.2 clutch is definitely firmer feel than acuras and the BMWs. But it is still a very robust clutch that feels very precise rather than notchy. The feel of the 997.2 clutch when I drive it immediately after driving my other 6 speeds reminds me of the feel I had when I went from a 2002 996 (3 year old) Carrera to a new 2005 6 speed 996 GT3. I just attributed to the fact that it was new, firmer and needed to be broken in. It felt as if the clutch spring mechanism was firmer. Didn't think much of it afterwards until now.
If you are bothered by the tranny, (sounds like you are) have a local tech test drive it. As firm as they can be, it should not feel broken.
#38
But in the mean time, i am going to blip the throttle and see if it helps. My main concern with second is downshifting. There is so much resistance, it's almost impossible to perform a smooth shift in a hairpin turn. The whole reason I bought the car.
But I have confidence the dealership will be able to fix the issue. It's a top notch place, and I am very happy I bought the car there. They seem very eager to help with the issue. Which is half the battle.
#39
If you are downshifting on a hairpin turn, blippng the throttle is a necessity in many cases. (Heel and toe). You can lose the tail pretty easily if you are turning on the corning at high speed and downshift on a turn without blipping. Don't do that. You will end up in a ditch. An extrem case of similar scenario would be drifting into a corner and suddenly letting go the accelerator. You will spin.
Frank
Frank
#40
Frank
Frank
I feel once I drive another 997.2 this week that is a stick, i will be able to come to a conclusion.
I will still keep your advice in mind though. Good tips...not to crash!
#41
Is the 6 speed as good as the PDK? My answer is yes and no.
The PDK is an amazing gearbox and I'm certain that 99.9% of drivers would be quicker around 99.9% of tracks in a similarly equipped car with a PDK than they would with a standard tranny. And I'm also certain that the PDK is a much better "daily driver" transmission.
But to some, myself included, it's just not the end all be all that it is to others. There's something visceral about the skill, effort, and practice inherent in a properly executed up shift or heel/toe downshift that the PDK will never be able to replicate.
I'm not Lewis Hamilton and I never will be. So I'll continue to trade the incremental pico second in acceleration and hypothetical track time for the joy of actually driving the car myself.
I don't get the "pico second" remark. First off, it will definitely be orders of magnitude more than a pico second. Secondly, the incremental acceleration is irrelevant - the difference is in how much speed was carried into the corner and how quickly the driver gets back to throttle. Lastly, I also don't get the "driving myself" comment. Then I must assume ABS was disabled, traction control disabled, throttle was physically connected to the engine, and there was no power steering. With the exception of ABS (since virtually no race cars use ABS), it sounds like a real race car you must be driving - not something I'd want to drive on the street.
#43
The only real way i will know for sure is when i drive another 997.2 stick for comparision. one thing is for sure, the shifting is workign, but that 2nd gear resistance KILLS smooth shifting at any speed. Porsche needs to figure it out i think, because if it's a characteristic of the transmission, then more will choose PDK I feel. Thats why i think mine might be defective. But only a trip to the dealer will prove it. I'll let everyone know what i find...
#44
While I agree that a properly executed heel/toe is a good skill, I would argue that its no more engaging than a PDK - you just trade off heel/toe for left foot brake. Having driven several cars [on many tracks] using both heal/toe vs left foot brake IMHO they are both equally engaging. Left foot braking allows for techniques in getting through corners that "clutchers" can only dream of. A perfectly executed turn using both throttle and brake properly is a thing of beauty (and extremely engaging).
Personally, I don't care if I'm a minute slower on any given road or track in a manual tranny car vs. a PDK equipped car. I'm not Ayrton Senna and I'm never going to be... I would rather be slow and enjoy the drive than fast and not enjoy it. But again, that's just me.
jjprusk's point about ABS, traction control, etc. is well taken but misses my point.
I'm driving on the road the overwhelming majority of the time. Traction control, ABS, power steering aren't taking any fun away from me on the road because I don't drive that hard on the road to even invoke ABS or traction control. But damn near every time I take the P car out of the garage for a drive I find opportunities to safely practice my heel/toe shifting and I (again, just me) really enjoy that. The PDK won't do that for me.
#45
drving the pdk, to me,is just as engaging, however, my left foot is bored! But, it is silky smooth, the PDK plus is awesome and I wouldn't change a thing! Basically, it comes down to each his/her own. After all is said and done, it is a Porsche, there is no substitute....!
