can someone explain my lumbar support
its a 4 sided button... round.. so up/down/left and right..
i press up and it inflates, i press left and it inflates more, i press down and it inflates i press right and it deflates, i press up and it deflates, basically i dont get what does what..
is their a rhyme to the reason or when its inflated the next button deflates.. or is one moving up/down?
sorry for the newb question but i was messing with it today sitting in the car and it seems like each time i go "around" the button does a different thing
The up and down button move the position vertically up and down while the right and left button inflate (closest to your feet) and deflate (closet to back of car) the bladder.
mine must be messed up.. thats what i figured it would do (makes sense)
ill try messing with the passenger one and see if it does it right.. im thinking maybe my button might have gotten turned and up isnt up.. cause up/down doesnt make it go up down.. but inflates and such..
Once you get the lumbar support where you want it you need to store the setting in memory. Every time you use the same key to unlock the door the lumbar support will inflate back to the stored memory. Switch the keys & all bets are off unless you also store the memory with the 2nd key.
PS - It took me 4 years to figure that one out.
