Rennline Fire Extinguisher Mounts **Product Release** $125
Old 12-09-2008 | 03:35 PM
Rennline's Avatar
Rennline
Basic Sponsor
Default Rennline Fire Extinguisher Mounts **Product Release** $125
Fire Extinguisher Mounts **Product Release** $125 retail
Also from Dec. 1st -25th all Rennline products are 15% off.
Fire extinguishers are mandatory in all cars that will see the track and should be mandatory in all street cars. There's no worse feeling then watching your car burn to the ground without the ability to do anything about it. Unlike most fire extinguisher mounts available, all of Rennline's mounts install directly to the factory seats and do not compromise seat travel or leg room in anyway. Constructed from aircraft grade aluminum and meets all requirements for racing series or other organized track events. Designed to be used with most standard 2.5lb fire extinguishers, all hardware and installation instructions are included.
To purchase this item please click here!
WWW.RENNLINE.COM
Orders@Rennline.com
Ph. 213-224-7393
Old 12-09-2008 | 04:12 PM
Edgy01's Avatar
Edgy01
Poseur
That price appears to be for the mount, alone. The FE is extra. Wow.
Old 12-11-2008 | 07:46 PM
tkids's Avatar
tkids
I take it that seat removal is required?
Old 12-11-2008 | 11:08 PM
leneuromancer's Avatar
leneuromancer
please excuse my ignorance ...is that good? bad?? high??? ugly???? ...or just plain rip-off?
thanks
Old 12-11-2008 | 11:27 PM
tkids's Avatar
tkids
thanks
Not to answer for Dan, but this is what I have found on the market:
Part #FEB_PORSCHE_0508 BRUSHED ALUMINUM BRACKET ONLY $69.99
FIRE EXTINGUISHER MOUNT, Exc. Cars w/Sport Adaptive Seats R-2035 $97
Old 12-12-2008 | 12:23 AM
Edgy01's Avatar
Edgy01
Poseur
I simply ordered one for my car from Porsche and it seems to have been a lot cheaper,--with the extinguisher tossed in.
Old 12-12-2008 | 10:20 AM
Rennline's Avatar
Rennline
Basic Sponsor
You will need to remove the 4 mounting bolts and tip the seat back to install this or any fire extinguisher mount that travels with the seat.
Old 12-12-2008 | 11:03 AM
tkids's Avatar
tkids
That is not so bad. Some require total removal of the seat from the car.
Thanks!
Old 12-12-2008 | 11:41 AM
Rennline's Avatar
Rennline
Basic Sponsor
It's basically the same game. Once the 4 bolts are out the seat is offically removed.
Old 12-13-2008 | 06:35 PM
ohsixx's Avatar
ohsixx
I first thought it attached to the passengers seat. Does anyone know of one that does?
Old 12-15-2008 | 09:36 AM
Rennline's Avatar
Rennline
Basic Sponsor
I don’t believe that you will find any of them that attach to the passenger side seat. There are control boxes mounted to the seat base that makes it impossible to mount anything to it. I'm sure you will find one that mounts to the seat rail but they will not move with the seat.
Old 12-15-2008 | 11:20 AM
AP997S's Avatar
AP997S
I've got the Brey-Krause Fire Extinguisher Mount (R 2035) and even though I mounted it on the driver's seat they claim it can also be mounted on the passenger set as well.
Old 12-15-2008 | 11:28 AM
Rennline's Avatar
Rennline
Basic Sponsor
There web site says "drivers side only"
Old 12-15-2008 | 11:50 AM
tkids's Avatar
tkids
This is what I found:
"For Power seats, it will work on both driver & passenger. On cars with manual seats, it will only work on the driver's side."
Old 12-15-2008 | 12:07 PM
Rennline's Avatar
Rennline
Basic Sponsor
Where did you see that?
Here is a link to the 2035 on there web site- http://www.bkauto.com/porsche/r2035.php
And here is the installation instructions of there site - http://www.bkauto.com/porsche/instructions/R2035.pdf
Both say drivers side only.
Quick Reply: Rennline Fire Extinguisher Mounts **Product Release** $125
