Battery replacement
I think my battery is on the way out - will get a check on it tomorrow. Any recommendations on what to get as a replacement?
MTIA
MTIA
Poseur
Can you cite a few issues with your car,--model year? Mileage accumulated on it? It seems premature to me for any 997 to need a battery this early,--unless you rarely drive it. The Chicago location may indicate that the car sits from late November to early May...
I had the exact same symptom with my 06 C2S (also 17k miles).
Mentioned it to my service adviser who informed me there's a TSB on starter cables for certain 997's. Mine was apparently "shorting." It was replaced under warranty.
I haven't had the car back very long, but the problem has not recurred, yet.
I just had the same thing happen to me. 06 C2S that sits in my garage (NY Area). Haven't used since Sept and the battery is dead. I charged overnight and the car turned over (barely). I left the charger in the front trunk and now I can't even open the hood. Completely dead.. Is there a bypass lever to open the hood?
Also, when it started, I got a PSM light failure. Prob due to battery issue. I spoke to the dealer and he mentioned to just come in, change the battery and they will turn off the light.
Anyone here have any similar issues? Thought I might buy the Interstate MTP-91 battery and replace myself. (will the light correct or do I have even worse issues??)
Thanks guys and Happy Holidays!
Chef,
My 06 is also a little slower this year to turn over in the cold weather as well. As I felt last year, it will start every time with just a little hesitation and then will resume normal cranking after the big thaw.
That being said, the car will probably die the next time it's cold out.
I replaced my battery with a Die Hard Group 47, it's a little smaller and has 590 CCA instead of 700 stock, it's been great and no problems. It fits in the factory tray with the oem bracket and I saved 20 LBS! It also has a 3 year warranty and it was $125. The stock battery is to big and heavy.
My dealer checked the battery and it needed replacing. Apparently raising and lowering the top 2 x day + shortish journeys didn't really help it to stay fit.
My 06 battery just went, dealer replaced with an Interstate for $145, said the Porsche replacement was $500+. In all fairness, I discharged the battery fooling with my Dension Bluetooth unit twice, but, I was still disappointed with OEM battery life.
Have about 23K miles.
Miserable Old Bastard
I'm at 52 months and 42K miles on my original 05 CS battery. I had it checked a few months ago since it sometimes seems a little weak on starting, but dealer said it was fine.
mission accomplished.. just picked up an MTP-91. followed Dave's hood pop instructions (thanks again Dave!) and dropped it right in.. fit like a glove.. went a local garage (2mins away) and they had one for me. (man the oem battery was heavy!) $130 bucks and we are up and running...
still have the psam falure light though! will take it to a dealer this week..
one thing to mention to others, the vent on the battery is oval and doesn't quite fit the elbow vent on the p-car so you need to put in a rubber conduit hose. (make sure to ask your garage if they can cut a 3-4" rubber hose for this to work)...
you people are awesome! thanks again!!
