SEATBELT WARNING TONE
20 Years ago I didn't always wear mine, then one day I used it. Both cars were totaled, not my fault. The thing that amazed me was how my nearly straight arms just buckled on impact like a ragdoll. The impact forces are just too great for a human to withstand. (Yes I did tweak the stering wheel a bit). I've never gone more than 10 feet since then without one on, that means even moving it around the parking lot I put it on.
I had the tech guy disable my seat belt chime. Instead of going on forever, it gongs seven times when the belt is unbuckled and then cuts off. It sounds quieter too.
Some service advisors who are worried about liability won’t write up disabling the seatbelt tone but the service tech will usually do it. I also had the mirror dip on reverse and door locking when moving off enabled.
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
Hopefully you didn't pay more than a couple hundie for the changes.
When driving around parking lots in LA looking for a spot, which can take a long time, I would often prefer to take off my seat belt except for the annoying chime.
I'm glad it can be disabled. I'll take it to an indy if the dealer won't disable it next time.
911 40th. Anniv..
911 40th. Anniv..
The mirror only dips on reverse when the mirror adjustment switch is set to the RH mirror. You just had to change the selector to the LH or ctr position. You can change the door locking via PCM I believe but you would have to RTFM to find this out.
Another option is to extend the rear belt forward and plug it into the front receiver. I do that when wearing the harnesses on the track.
