Peeling Switchgear and interior finishes - & PCM? Head unit/cd acting up
I've noticed that my switchgear on my 997S is peeling - much like the old beckers in the 9X6's. SPecifically the fan switch on the right hand side of the heater control area.
I have also noticed that the ashtray is peeling/ finish is soft / coming off, and the head unit and climate control unit is acting up (has a mind of it's own). ..I.e a CD will play, then a few days later it wont read any CDS -- and then it's fine a few days later.
Have others experienced these problems, and did the dealer just end up doing a warranty claim and replacing the climate control & head unit entirely ?
There's an issue with the oils from skin on many of the current plastic surfaces that cause some to 'disassemble' more quickly over time. The remote control fob for my 94 VW pretty much wore smooth / melted / rotted the rubber buttons after 5 years of daily pressing the thing and holding it in my hands. The steering wheel cover is now getting soft after 14 years. The dash, which I don't put my hands on much at all, is holding up perfectly well.
Because there are many different types of materials (and several different types of plastic) used for the interiors of automobiles, it is often necessary to paint many, if not all, parts in order for them to look the same ( different materials have different surface characteristics). Therefore, oils, acids, salts from the skin or, even worse, using hand cream or sun tan lotion, etc, will soften and / or degrade the coatings. Generally, there is a better chance to avoid this problem with black interiors as there is often a reduced need to panit the parts but I must say that I am surprised to read about the situations described above.
