PCM 2.1 head unit + navigation dvd module
hey guys,
i have for sale an almost new PCM2.1 head unit and navigation dvd module. i retrofitted these items into my 08 7gt3. unfortunately i found out later that these items were not compatible with my current ASK amp (analog). the ASK amp is the factory amp used if you have the Sound Package Plus on the 7gt3. the Bose option was not an option for the 7gt3. this PCM 2.1 head unit was programmed from the factory to only work with the BOSE amp.
PCM 2.1 NAV SCREEN - part# 997.642.143.10 (programmed as BOSE output, uses MOST cables to go with BOSE amp)
Navigation Module DVD Player - part# 997.642.157.01 (includes 5/2007 dvd disc)
this setup will work perfectly for all 997's which has the BOSE amp. please check out this link from Suncoast for pricing comparison. also if your in the bay area, i can help you install this item in your car. you'll also need to purchase the GPS antenna and cable, MOST cable, DVD drive bracket and associated clips.
im asking $2500 OBO for local pick-up. but willing to ship at buyers expense.
