Trade the Z3 for a Boxster ??
You'll see a huge difference between the Z3 and the Boxster. The Boxster has nay-sayers, but take it from an owner...it's a well tuned and defined car. Believe it or not, the Boxster can be more fun to drive than the 997.
I drove a Z3 before buying my first Boxster, and then moved to a Boxster S (2001). I could not believe what a POS the Z3 was ... it felt like it was a bunch of random bits bolted together without ever being designed to work as a single car. The Boxster, though, was tight and tied down - felt wholly integrated as a system.
Make the move ... you will only be mad at yourself for not starting with a Boxster instead of the BMW.
Lorne
Lorne
Bottom line is that I would recommend test driving a Boxster S. I believe that you will be pleasantly surprised. On the other hand if perception is important to you, there's nothing wrong with a 911 vert. I'm certain that there are excellent 996 verts that you buy at a very reasonable price.
Good luck.
Yes, get the Boxster S - you will see why it's a cult car among all but the "chickster hater" crowd. It is a fully sorted true sports car that I will miss when I sell it! Huge difference versus the Z3 (had an M), and only a smidgen less fun (about 75hp would fix this) to drive than a Gt3!
I would certainly choose a 987S over a 986 cab - the Boxster S will give a base 997 a run around most tracks.
Unique Title
Give one a drive, just remember to put your checkbook in a safe place or you'll wind up doing what I did...buying it on the spot.
There's a reason my avatar is my Boxster and not my Carrera...
