Another Radar Detector Hardwire (Escort 9500 smartcord)
#32
Thanks for clearing that up Coochas. One more question, for this install did you use the direct wire power cord or direct wire smartcord? You mentioned smartcord but I believed you meant power cord.
Smartcord https://www.amazon.com/Escort-Direct...RD338MKQGK31JH
Power cord https://www.amazon.com/dp/B0003NN83U...ing=UTF8&psc=1
Or
https://www.amazon.com/gp/product/B0...A13BNE3P7C8THK
Or
#35
I followed these instructions ages ago using the Smartcord - have the little controller at the bottom of the a-pillar on the dash (small piece of double-stick foam tape) - makes it easier to mute. I did this with a 9500ix, but still works with the new 360.
Or
Or
#36
I plan to DIY install the 9500ix and want the cleanest look as possible. I have sand beige interior and will be using beige velcro, brown electrical tape (since I cannot find beige).
Is the actual 9500ix unit that hard to mute or mark the false alarms if it will be mounted under the rearview mirror? I don't think I want the extra gadget - smartcord if it's not that much more useful
#37
Rocky Mountain High
I also have Sand Beige interior and I wanted a clean look. I ended up going with the Blend Mount, and I'm very happy with it.
#38
If you used the direct wire power cord, is it easy to mute and mark false alarms at the location of the 9500ix on the blendmount (below the rear view mirror)?
#39
It's a fairly clean look and very handy...
#40
Rocky Mountain High
Nice, I already planned to purchase the Blend Mount. Now did you use the direct wire power cord or direct wire smartcord?
#41
Yes, super easy to reach. I have a Max 360 on a blendmount and it's easier to reach for muting then when it was mounted low on the windshield suction cups near the dashboard. In my case a smart cord with remote mute button would be overkill. Direct power is all you need.
#44
You guys are making me feel guilty that after my C4S (the above write up), I never took the time to reinstall the hardwire in my 2009! I'm glad this pictorial is still helping people although it was not my original idea. Cheers.
#45
I used a direct wire cord, not a direct wire smart cord. I'm using the Passport Max 2. I will admit, access to the buttons on the top of the unit is a little bit tight. That being said, this isn't an issue for me because I have the auto mute feature activated on the Passport.
It looks like you wouldn't be able to put the wire behind the roof liner since you have no roof! lol.
