Brake upgrade?
Old Feb 29, 2008 | 02:38 AM
MyEmily's Avatar
MyEmily
Default Brake upgrade?
Was going through Suncoast part list and ran across a set of 6 piston brake caliper for the 997. Is it worth the upgrade other that going to PCCB? $2600 direct replacement of the factory 4 pistons version. DO I needed? Do the C4S have 4 or 6 pistons up front? Also, best brake pad for street use? ANy Rec? TIA
Old Feb 29, 2008 | 03:36 AM
Vancouver83LTD's Avatar
Vancouver83LTD
I'd go aftermarket first
Old Feb 29, 2008 | 06:56 AM
eljeffo64's Avatar
eljeffo64
Just as a matter of interest; why do you feel the need to upgrade??
Old Feb 29, 2008 | 08:23 AM
RonCT's Avatar
RonCT
Moderator
Like he said - are you running out of brakes? If so, it's probably some other problem (boiled fluid, air in the system, etc.) Are you having fade issues? Point of reference, I've been enjoying my 997S on the track very much, especially at Cups & Saucers at Watkins Glen. That event is 7 hours of track time in 2 days (30 minutes on, 30 off). Zero fade. The only issue is front rotors are spider cracked now at 7500 miles and so I'm replacing them once a year ($340 oem rotors delivered + $100 labor).
Old Feb 29, 2008 | 11:57 AM
911Dave's Avatar
911Dave
You can upgrade your brakes all you want but you're not likely to stop any better. You should always remember that it's the tires that stop the car, not the brakes. Tires are what make the car go, tires are what make the car corner, and tires make the car stop. It's all about tires. Specifically, it's all about maximizing the friction between the tire and the road surface. Most of that has to do with the size of the contact patch.
Your stock 997 brakes already are among the best in the world, on any car. They can easily cause your wheels to lock up and tires to skid all day long. The weaker link is your tires. So, that's where you should spend your money. When your brakes can no longer keep up with your tires, that's when to consider a brake upgrade. The one possible exception to this would be PCCB's, which can provide a handling advantage due to reduced unsprung weight.
I think it's always good to approach any consideration of mods from the perspective of maximizing the friction between the contact patch and the road. Why do we like negative camber? Because it improves the contact patch during cornering, and therefore the tire's ability to hold the road at a faster speed than before. You can put a 1,000 bhp motor in your car but you'll be wasting that power if it makes your wheels spin. Similarly, suspension components and setup are all about keeping the most rubber on the road for the maximum amount of time. If you can always think about it like that, it will be easier to know what will help your car's performance and what won't. Tires are almost always the most important component on the entire car.
Old Feb 29, 2008 | 12:05 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Brake UPGRADE? I just love the number of new Porsche owners who feel some compelling reason to "upgrade" their cars and uptimately make them worse. You will be hard pressed to improve upon what you already have. Of course, all the aftermarket guys will tell you about how great THEIR systems are...
Old Feb 29, 2008 | 12:24 PM
adfsouth's Avatar
adfsouth
Yeah....what they said
Old Feb 29, 2008 | 12:52 PM
996toomey's Avatar
996toomey
I have never been into changing or modding Porche. I like OEM. One mod I would consider is wheels to reduce unsprung weight but probably will never do it.
The cars are engineered so well from the factory I think it is very difficult to improve on. If your driving abilities have out grown your current car probably better in the long run to sell it and get another. For instance if you have a base model and are bored with it or have exceeded the car's abilities maybe get an S. If you have an S maybe get a GT3 and so on.
If you just don't like the way the calipers look maybe have them painted. I believe I have read on one of the forums people doing that for around $800., by a professional not in the garage with a spray can.
Old Feb 29, 2008 | 05:06 PM
MUSSBERGER's Avatar
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
Oh a wise guy ehh
File Type: jpg
Old Feb 29, 2008 | 05:07 PM
Crazy Canuck's Avatar
Crazy Canuck
why?
Old Feb 29, 2008 | 05:11 PM
RonCT's Avatar
RonCT
Moderator
Forgot to answer the street pad question. The OEM street pads really are fantastic - they even held up to hard track use as I was getting used to this car (running 1:05 at Lime Rock in Black - which is already down to 1:02 but with race pads - PFC97).
Old Feb 29, 2008 | 07:42 PM
roberga's Avatar
roberga
If this is a street only car... save your money. If you are going to the track with the car and it is your first season spend your money on a good driving coach. Tires and brakes go together.
Old Feb 29, 2008 | 09:31 PM
PogueMoHone's Avatar
PogueMoHone
+1
Old Feb 29, 2008 | 11:06 PM
RonCT's Avatar
RonCT
Moderator
Even if this is a track-only car, brake upgrade is hardly necessary - even in the Black / Red run groups. Race pads? Yes (PFC 97s). $29 better cooling ducts from GT3 - sure, not sure if they help, but cheap. But changing brakes? Never...
Old Feb 29, 2008 | 11:30 PM
sclemmons's Avatar
sclemmons
Coming from the BMW world of comparatively sucky brakes, Porsche is reputed to have the best brakes on the planet. Imagine the product liability issues associated with brakes. Just seems to me prudent to stay with the factory product particularly when the bar is set so high already.
