Porsche requires a "full tank of gas" for an alignment?
Old 02-19-2008, 03:56 PM
Hauser_III
Hauser_III's Avatar
Default Porsche requires a "full tank of gas" for an alignment?
I took my "waiter" C2 in for an alignment this morning, because the straight-ahead has been off since I got it three weeks ago. The service advisor just called to tell me that the alignment was done, and informed me that there would be a charge on the ticket for filling up the gas tank, because "Porsche specifications require a full tank of gas in order to do an alignment correctly."
They're not throwing dealer mark-up on top of the fuel bill, so this isn't a rant about the dealership. But I've had several alignments done at this dealership previously, and never once have I been told that I should have brought it in with a full tank, and never once have they filled the tank up before today. So, is this one crazy, or did they do the right thing to fill it up before doing an alignment?
Old 02-19-2008, 03:59 PM
Benjamin Choi
Benjamin Choi's Avatar
talk about splittin hairs.
Old 02-19-2008, 04:03 PM
roberga
roberga's Avatar
makes sense to have a standard for all dealers.
Old 02-19-2008, 04:05 PM
MrBonus
MrBonus's Avatar
I was told the same thing except they called me before doing the alignment.
Old 02-19-2008, 04:07 PM
MJones
MJones's Avatar
The dealer is correct!
A full fuel tank is called for in
"Adjustment values for suspension alignment"
The following values relate to the empty weight. i.e. full fuel tank, vehicle with tools but without driver or additional weights.
Old 02-19-2008, 07:53 PM
mdrums
mdrums's Avatar
Tank should be full and weight should be put into the drivers seat.
Old 02-19-2008, 08:10 PM
911Dave
911Dave's Avatar
Yup, a full tank is correct. Your previous alignments were done incorrectly.
Old 02-19-2008, 10:02 PM
othomasjr
othomasjr's Avatar
Can just anyone align these things if they are properly ballasted? Or is it some special deal that requires Porsche tools, etc.????
Old 02-19-2008, 10:38 PM
996toomey
996toomey's Avatar
I didn't know that but suspected as much. I stopped and filled up before having my alignment done a couple of weeks ago.
Old 02-19-2008, 11:15 PM
Analog Theory
Analog Theory's Avatar
FWIW our Motorsport alignment including corner balance is a 1/2 a tank of fuel and driver's weight. Fuel level as a variable in this process is very significant.
Old 02-20-2008, 01:42 AM
mdrums
mdrums's Avatar
Yes but you can not corner balance a stock 997 or 997S. You need seperatly adjustable shock like the Bilstein Damptronics.
Old 02-20-2008, 09:43 AM
Hauser_III
Hauser_III's Avatar
Thanks for all the responses. It's good to know my dealership did it right this time, but Im still curious why they didn't do it on previous alignments for my '06C2S. Who knows, maybe I just happened to have a full, or nearly full, tank when I came in for the prior alignments? I've got a real good relationship with my dealer, so I'm willing to give them the benefit of the doubt.
Old 02-20-2008, 09:56 AM
WAC
WAC's Avatar
So, if you want to corner balance your car you've got to modify the shocks. How does that affect PASM?
If you install new adjustable shocks how much more trouble is it to add in the required parts to make caster and camber easily adjustable? Any idea what that would cost?
Tony
Old 02-20-2008, 11:16 AM
Analog Theory
Yes exactly, but the point being that a baseline for fuel load is relevant to the process with or without ride height adjustability.
Old 02-21-2008, 12:26 AM
mdrums
mdrums's Avatar
Tony
If you have the Bilstein Damptronics installed you can set the ride height, corner balance the car and still use the PASM sport button to stiffen up the shocks.
If I was keeping my 997S for more than a year or 2 I would have this system on my car as my 1st mod along with the GT3 control arms so I can dial in more camber upfront...but i go to the track a lot so this is a great mod for me.
Quick Reply: Porsche requires a "full tank of gas" for an alignment?
