HELP! Backed into a mail box...
It made a small indentation in the rear bumper above the license plate. Any ideas about how to get it out? I thought above putting a hair dryer on it.
Newbies Hospitality Director
Is the paint cracked? If not and hair dryer might work, but it may not get hot enough to be able to pop the dimple back out. You could take it to a repair place if the hair dryer doesn't do the trick.
Check out Rick in Colorado's thread (serendipity??) just posted:
https://rennlist.com/forums/997-forum/410430-diy-dent-removal.html
Concept seems sound - heat then quickly shrink causing the body panel to seek equilibrium (original position). If you try it, pls advise if it works.
Caveat: Credit (and blame) to Rick if it doesn't
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Maybe I should have gone with a more louder color like a GT3/RS color.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Excuse me while I go and remove the dust that just landed on my black finish.
Deanski
I'm one as well. Why the hell I went back to black bothers me, but once I see it clean, there's nothing like it at night.
Maybe I should have gone with a more louder color like a GT3/RS color.![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Deanski
Deanski
The dent is so minor that I don't think it will show up in a photo. I know it's there but you would really have to look for it if you didn't know it was there.
If it is that small then I would imagine a little heat will probably induce it to return to its original shape. A good repair shop will probably have a heat gun and could work their magic in 20 - 30 minutes.
1 Post
If you notice the dent, then that's all that matters. I had a similar issue -- when I had my radar detector installed, it wasn't placed properly inside the bumper and was pressing out against the bumper to create a small bump. I took it in to a high end repair shop, and they heated the bumper and the pimple was gone. I highly doubt that a hair dryer will generate sufficient heat to fix the dent.
