Dension Gateway 500 MOST connection
I got my Dension Gateway 500 kit for iPod connection to PCM yesterday.
Does anyone know which MOST installation type/connection I should use. My car has navi., but no CD changer unit (and no wiring for CD changer unit).
The installation types can be seen here: http://support.dension.com/downloads...tall_Guide.pdf
Thanks.
Thanks.
I just installed a Dice Electronics unit and my car does not have the Nav or CD changer. Your car should be wired for the changer. Take a look in the trunk next to the master brake cylinder. You may have to unscrew the cover and look for 2 orange fiber optic lines wraped in black plastic. You can connect there if you wish or just be sure to loop it if connected elsewhere.
Good luck.
Good luck.
Thanks.
Thanks.
