Premier Garage vs. Life Deck Epoxy Floors
I'm doing an addition and part of it is an attached garage. I have been looking at both surfaces as well. I'm leaning towards the Race Deck.
http://www.racedeck.com/
But I still have a few weeks before I really have to make a choice.
Timely
Timely
Anyone try MOTO FLOOR, looks to be a RaceDeck copy, but selling at costco for 1.88 sq foot??
I priced racedeck out and it is as follows:
under 500 sq ft = $3.49 sq/ft
Over 500 sq ft = $2.99 sq/ft
While I considered racedeck, I ruled it out because I couldn't get over putting plastic tiles down on my floor at $3.00 sq/ft. Certainly no less expensive than doing epoxy floors and I don't believe they will be as easy to maintain over time.
The color is called Sedona.. They recommend only coat of the top coat, a second coat was an option but Premier claims that when the floor gets wet it becomes very slippery with more then one coat. After a year or so depending on wear they can come back and add another coat to keep the floor looking new...
I did decided to go with Premier and just had my floors done yesterday. I also had them build a special closet to enclose my water heater and central vac. They did a great job! I will post pictures soon.
I went with Bigfoot tiles and nearly a year later, they are in great shape other than the usual road grime that manages to attach itself to tires and subsequently the floor.
See my write-up here from last March:
https://rennlist.com/forums/showpost...19&postcount=1
rzundel- we went with desert as the sedona looked too pink with the cabinets and wall paint we had already selected. The sedona has a tendancy to read pink unless you are very careful with the paint color you choose. Plus the desert hides so much more in terms of dirt, sand and debris.
Yes, Premier did the cabinets, the stainless steel counter tops, and the wall storage system. I went with the 1/4 flecks as the 1/8 apparently does not look as good in large garages. Also, the 1/8 flecks made the floor feel like sand paper which I thought may be more difficult to sweep. If you feel the smaples in the 1/4 and the 1/8 you should be able feel what I am talking about.
