PCCB Swap
Old Jan 5, 2008 | 08:29 PM
KeninBlaine's Avatar
KeninBlaine
Default PCCB Swap
Can a set of PCCB rotors and calipers be directly installed in place of my stock equipment on my 05 C2S without any other changes?
Old Jan 6, 2008 | 12:37 PM
nkhalidi's Avatar
nkhalidi
You might need new caliper brackets, but it should be a relatively easy swap. Call Suncoast parts dept for specifics: http://e-partssales.com/Merchant2/me...997CarreraSbra
Old Jan 6, 2008 | 02:23 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Absolutely not. There is considerably more to this than simply rotors and calipers. The bearings are completely different and the ABS is mapped differently. When you assemble the entire parts list it well exceeds what it was just to order it in the first place on your car.
Old Jan 6, 2008 | 05:14 PM
KeninBlaine
Thanks Edgy. Being somewhat skeptical, I usually figure things are not as simple as they may appear, or as we want them to be. Appreciate the help you provide in this forum on many topics.
Old Jan 7, 2008 | 01:06 PM
Dr. Car's Avatar
Dr. Car
Do you know how the different ABS maps affect performance? I would think that the standard maps would still accomodate PCCB at-limit braking, because the issue is the same: monitoring wheel speeds and keep the tires from locking up. I figure the different map has to do with how quickly the PCCB system responds to a change in hydraulic pressure to the caliper, due to different friction surfaces and different calipers. But of course the response is going to vary greatly within the same brake system if the owner switches from one brake pad to another, e.g., someone gets cheap replacement pads or serious track pads for the OEM brakes. I wonder if an OEM PCCB responds "more different" than the OEM iron brakes, than the difference between OEM pads and say Hawk Blacks.
Old Jan 25, 2008 | 01:33 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
There are several variables in this, e.g., wheel response (less unsprung weight) and differing coefficients of friction,--after extensive testing, Porsche has developed differing values. It's not to say that you can't plug them in perhaps, but be aware that they differ.
Old Feb 15, 2008 | 09:28 PM
MLindgren's Avatar
MLindgren
"I'm late to the thread but if Stop Tech is still counting interest, add one more. I have PCCB on two of my Porsches with a 3rd on the way. They make a significant difference. Would love to have some for my FGT."
A strong thumbs up from one of the Ford GT owners in regards to PCCB.
Old Feb 15, 2008 | 11:11 PM
Deanski's Avatar
Deanski
It's always interesting to hear from owners wanting the PCCB's after the build or CPO purchase of a C2S. Wonder why those interested in changing to PCCB's want the PCCB's when the steels are just as good for street use?
Painting/powder coat your calipers yellow is a whole lot cheaper.
On the other hand, quite a few of us PCCB owners do the exact opposite! We want to switch to steel rotors to save the rotors, or other reasons for track use.
I went with the PCCB's over X51 seeing that spending 17K for 26Hp and 8K on brakes that could possibly last a very long time, have less weight than steel, feel better when abused and somewhat mistique of these is why I went with them. Never had ceramics and always wanted to have a car from the factory with them.
So, I tend to agree there is more to it than a simple swap.
You may want to check RENNTECH site for the very same question as I'm sure it was brought up. Or reach out to the "Club" tech support on this one.
Regards,
Deanski
Old Feb 16, 2008 | 12:08 AM
Dale Gribble's Avatar
Dale Gribble
Pocket Sand
considering the parts cost of PCCB rotors and calipers and whatnot, it might be cheaper to get aftermarket stoptech or brembo big brake kits..or even their Brembo GTR kit which will outbreak the PCCB's.
are PCCB replacement rotors still stupidly expensive?
Old Feb 16, 2008 | 01:40 AM
KeninBlaine
As the one that started this discussion, I was originally intrigued by a set of PCCBs someone advertised for $6200 (4 rotors and calipers). I hadn't thought seriously about needing them, but the idea crossed my mind when I saw them advertised. I decided it was too complicated for something I didn't really need or want that badly. It seems the weight saving is the biggest benefit, which isn't that important to me.
Old Feb 16, 2008 | 01:57 AM
Chris Prack's Avatar
Chris Prack
I have swapped steel rotors onto PCCB cars on several occasions with no ill side effects. Don't really see where the problem would be. Seriously. What do you really think is going to happen? The whole idea is to stay out of the ABS anyway.
BTW I am a Porsche tech and have been to Porsche training so yes I am familiar with not only the system but the strategy FWIW.
Old Feb 16, 2008 | 03:51 AM
JFScheck's Avatar
JFScheck
Are you tracking your car? Why you need the ceramic brakes other than for yellow calipers?
Old Feb 16, 2008 | 06:35 AM
MLindgren's Avatar
MLindgren
For the same reason I need a Porsche over a Corvette-because they're the best in terms of refinement /engineering. Taking money out of the equation I see no reason I or anybody else wouldn't want PCCB and I didn't buy my Porsche to save money or as an investment.
Old Feb 16, 2008 | 02:23 PM
JFScheck's Avatar
JFScheck
Originally Posted by MLindgren
Taking money out of the equation I see no reason I or anybody else wouldn't want PCCB...
Yea, taking money out of the equation free's up alot of options in life...
Old Feb 16, 2008 | 08:43 PM
MLindgren's Avatar
MLindgren
Probably why they are able to sell X-51.
