Nav problems
Old Nov 15, 2007 | 07:16 PM
BGA23's Avatar
BGA23
Default Nav problems
I'm having an issue with my navigation, the map shows me about 150 miles from my actual location and it doesn't change. And when I try and use the nav to get directions to seems to think I'm somewhere other than where I am actually at or where the map shows me located. For example, I tried to use it to get home from the gym today when I was a few miles away. It told me to make a U turn (even though I was going in the right direction) and it said I was 14 miles away.
I've tried pulling the fuse in order to get it to reboot but removing it didn't have any effect.
Old Nov 15, 2007 | 08:21 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Try pulling the fuse and then pulling the DVD out of it. Do a hard restart.
Is this a MY05 car? Some have noted in the past that antenna placement issues cause this problem. Was sorted out in later cars.
Old Nov 15, 2007 | 08:49 PM
BGA23's Avatar
BGA23
It is a MY06.
I've tried pulling the DVD and the fuse but it didn't make a difference. I'm not sure if it did a hard reset, I would have assumed this would have resulted in clearing the radio station memory but they're still there.
Old Nov 15, 2007 | 09:44 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Keep the fuse out for at least a couple of minutes. I ran into this one time only here in the USA and after reloading the DVD it eventually cleared itself. Never repeated.
Old Nov 15, 2007 | 10:09 PM
Rolf Stumberger's Avatar
Rolf Stumberger
I had the same problem when the car was only a few months old.
It indicated my car about 30 miles from actual position.
It turned out that the antenna was defective and it was replaced under warranty .
Old Nov 22, 2007 | 03:29 AM
useridchallenged's Avatar
useridchallenged
I simply restored the factory defaults for the nav unit (under nav settings, I think) - that solved the problem. No fuses to pull or DVDs to remove. FWIW, I have a button happy 12 year-old, and I think some random button combo seemed to wedge up the nav map.
