5mm spacers
What are your thoughts on 5mm spacers, are they worth it? It seems hardly noticeable. Will they improve the track or will I even notice the difference?
thanks
thanks
Poseur
5mm is nothing. I have long suspected that their real need is to help deconflict a particular wheel from a particular brake caliper. I could never imagine anyone bothering to use them to increase track. 5mm is nothing.
I have 5mm fronts and 15mm rears. I can tell you that for the 5mm, you'll be hard press to see a difference, unless you look very closely. Now the 15mm on OTOH really makes a difference in the looks dept. Handling, I haven't noticed any differences compared to stock.
Porsche designs a rather neat car. To add spacers creates another problem, dings. There are enough with the stock car. I have a white car and I know! I do have spacers in the front because of my track wheels and had to buy longer lugs even tho they were the min thickness. Just my 2 Cents.
I do not think you will notice any change in handling with 5mm (speaking from experience).
The visual difference is slight but noticeable.
see https://rennlist.com/forums/showthre...ght=5mm+spacer
As Dan mentioned, most people use spacers not for handling but for aesthetics or to keep a particular offset wheel from mashing the calipers. In the winter, I run rubber that is 40mm narrower than stock rear rubber,...I ran 19mm of spacer last year and will run 32mm next season. This also serves to 'align' the front & rear tracks better in the snow tire application.
I agree w/ all the comments; you won't see a handling change. It does line the wheel up better w/ the fender lip (looks only).
PM me if you're interested.
