The H&R Wheel Spacer thread - 997 Widebody
Former Vendor
I've had several inquiries, so here's what I have from H&R:
Hubcentric.
14957161, 7mm = $65 a pair
1455206, extended lugbolt= $6 each
30957161, 15mm - $96 a pair
1456006, extended lugbolt $6 each
36957161, 18mm Cost $104.00 a pair
1456306, extended lugbolt $5.95 each
Available by special order:
46957161, 23mm Cost $130.00 a pair
1456806, extended lugbolt $6 each
In stock the best I can keep them. IF YOU ADD SPACERS, YOU MUST HAVE LONGER BOLTS.
Give me a call if interested, these are not available through our website. Of course, you assume all fitment issues if using these.
Hubcentric.
Last edited by brad@tirerack.com; 05-22-2010 at 04:59 PM. Reason: 2009 price update.
Originally Posted by kayjh
I'm new to all of this. Can you explain the purpose of wheel spacers? I notice Porsche offers them as a factory option as well. Thanks.
http://www.flickr.com/photos/8258154@N05/
Originally Posted by cleanme
Primarily for looks, I have 23mm spacers on all wheels and it makes the rear tires really fill out the wheel wells. However, 23mm is a little too big for the front, the 23mm added some 'twitchiness' to the steering. Here are some pictures of mine showing the wheels,
Mesage me if you're interested.
Clean me. I think 17mm for the rear and 7-10mm for the front will be better for you.
What exhaust tips are those? The fill the outlet space in the rear bumper very nicely.
It's a complete fabspeed exhaust setup, the tips have a nice bevel to them that IS polished but it quickly gets dirty from the exhaust.
I like the rear setup so I'll keep it that way. I might change the fronts come winter.
Used H&R 15mm spacers with new (longer) 60mm bolts.
Car before spacers
![](http://www.d30-images.com/911/spacers/IMG_4350.jpg)
Wheel off - hub face clean and ready to take spacer
![](http://www.d30-images.com/911/spacers/IMG_4351.jpg)
Spacer fitted - nice locating screw feature lines everything up and keeps the spacer on the hub while you mount the wheel.
![](http://www.d30-images.com/911/spacers/IMG_4352.jpg)
As you can see, adds a nice step out for the 997 alloys on the 996
![](http://www.d30-images.com/911/spacers/IMG_4353.jpg)
New 60mm longer wheel bolts (essential)
![](http://www.d30-images.com/911/spacers/IMG_4355.jpg)
Replace wheel, star pattern torque to 96lb-ft, and voilà!
![](http://www.d30-images.com/911/spacers/IMG_4356.jpg)
![](http://www.d30-images.com/911/spacers/IMG_4361.jpg)
Spacer visible through the wheel
![](http://www.d30-images.com/911/spacers/IMG_4362.jpg)
Handling is great - no wobbles with these hub-centric spacers.
Turn-in is sharper - car feels nice and planted through turns.
Originally Posted by cdodkin
Here's an H&R install I did on my 996 to adapt the 997 wheels to my car.
Car before spacers
Car before spacers
What Toyo tires are those?
Best tire I've tried so far - and I've tried a few!
I like the grip and ride - and especially like them in the wet compared to any other tire.
Sidewall supports the 911 rear engine just fine, no obvious over flexing - and it has a nice bead to protect the lip of the rim.
Actually they are 235/35/19 and 315/25/19 Toyo PROXES T1R
