Taillight Installation
Old May 31, 2007 | 05:12 PM
ziege's Avatar
ziege
Default Taillight Installation
Can anyone help me with instructions on how to R & R a 997 passenger taillight.
Had a little problem in the garage, and a ladder ended up breaking the light.
Can't find anything on search...
Thanks!
Old May 31, 2007 | 08:29 PM
NAvyC4S's Avatar
NAvyC4S
Thanks!
my 996 has two torx screws when you open the engine cover on the side of the tail light. I'd assume it would be similar if not identical to the 997. Once you take out those screws, you pull the tail light to the inside and it should "pop" out
Old May 31, 2007 | 08:44 PM
997driver's Avatar
997driver
The only screw you need to remove is the phillips screw. As soon as you unscrew that one screw, go ahead and pop the tailight off. Should take 45.9 seconds.
Old Jun 1, 2007 | 12:52 AM
Speed's Avatar
Speed
Read the manual. There are instructions on removing the taillight to replace the bulb.
Old Jun 1, 2007 | 01:24 PM
ziege's Avatar
ziege
Fantastic, sounds easy. I'll take a closer look when I get back into town.
Thanks for the help!
45.9 sec, too funny!
