Assorted Maintenance Items
Old Mar 25, 2007 | 10:09 PM
Guest
Posts: n/a
Question Assorted Maintenance Items
A few items that need attention @ 1700 miles.
1) Slow speed (20 mph and lower) brake squeal is back. Thoroughly rinsing the brakes (when cold of course) only worked for about 2 weeks. High speed hard braking did nothing to quiet this down. As I mentioned previously, never had this problem with a Porsche before; MB yes, Porsche no. BTW, the only way it was permanentely corrected on the MB's were to change the pads and rotors and on the last MB just changing the rotors did the trick (car had about 1200 miles).
2) Sunroof weather seal is making a rubbing noise when the car goes up/down(in reverse) an incline. What does Porsche use to lube/quiet the rubber seal?
3) Quite a few posts lately about dead batteries etc, I've noticed on the two 997S's I've owned, the starter spins rather lethargically when cranking, wondering why this is or if it may be related to poor/defective batteries?
I welcome comments or suggestions....
Old Mar 26, 2007 | 05:55 AM
dstrimbu's Avatar
dstrimbu
1.) My low speed squeek went away after about 6 threshold braking events from 120-20mph. Of course, that's hard to do unless you can find a convienent, newly built industrial park nearby with a 1/2 mile long new concrete boulevard. Head down one side, build speed to 120, activate ABS. DON'T STOP! Loop around, cool brakes at about 40-50mph, then loop back and do the 120-20 cycle again. Don't rinse, but repeat 5 or 6 times. My brakes are silent now. YMMV - this is not a scientific exercise.
2.) I use Gummi-Pflege from Einszett. I think the dealer uses the same on seals. M-B repackages the stuff, so does BMW.
3.) I got lucky with a solid battery. I do agree that, after 2 weeks parked, the starter spins rather slowly. Get a Porsche battery tender and get it over with.
Just MHO. Good luck!
-don
Old Mar 26, 2007 | 02:02 PM
elh0102's Avatar
elh0102
Assuming you are using the OE pads, and you are confident you did the bedding appropriately, that's about all you can do. There are lots of anti-squeal compounds available, but I doubt if any are as effective as the sound dampers that come on the OE pads. There are low-noise/low-dust pads available, and they are fine for street use; just won't hold up under lots of heat.
Old Mar 26, 2007 | 02:57 PM
Guest
Posts: n/a
-don
Thanks Don.
Yesterday I tried four hard braking stops from about 90 to 20 with no change.
I will locate the Gummi-Pflege for the roof.
I find it amazing we now have to get battery tenders...never had the need for this with past Porsches, MB's, BMW's or Ferraris I've owned; I can understand the need for a tender is a car if left for a couple of months but anything less makes me believe Porsche needs better batteries. I wonder if anyone upgraded to a better battery?
Old Mar 26, 2007 | 03:03 PM
1999Porsche911's Avatar
1999Porsche911
Probably vibration from the back of the pad not sitting properly. I always use rubberized anti brake squeal spray on the back of pad to prevent just this problem.
Old Mar 26, 2007 | 05:10 PM
99firehawk's Avatar
99firehawk
2. porsche part number for the top and seal lube 999 917 557 00, I always call it nasa lube its great, but its not cheap
3. pretty normal, the 997 is a high compression engine and just doesnt spin all that quick as long as it is starting with no real difficulty, i would not even think about
Old Mar 26, 2007 | 07:34 PM
Guest
Posts: n/a
thnx
