Removing 997 Front Bumper Cover?
I was really looking for that link work the other day and ended up "winging it" on my bumper cover. Count me as someone who'd like to see that gallery fixed...
Hello everyone, this is Mike, sorry that the DIYs I made were deleted by Rennlist. in fact 80% of them are gone. They were stored in Rennlist photo albums. I don’t know why they got rid of that department. Most likely for storage issues. I will try to find old pictures and maybe redo them again in the forum side
The only thing that was hard on the bumper removal are the clips beside the headlights that you wouldn’t know were there.
There is a guy on YouTube who has recently posted a couple of videos regarding removing and replacing his front bumper. His YouTube handle is "Auto Amateur". The YouTube video link (I hope this links!) is
There is a guy on YouTube who has recently posted a couple of videos regarding removing and replacing his front bumper. His YouTube handle is "Auto Amateur". The YouTube video link (I hope this links!) is https://www.youtube.com/watch?v=oP_AwShN5Qc
The spring clip is removed with a hook tool. It's located between the headlight and frunk just behind where the bumper meets the metal fender. It needs to slide about a half inch to let go of the tongue inserts from the bumper. You want to insert the hook into the hole on the end of the tongue clip that is facing your frunk. You will pull that tongue clip towards the center of the car... Be CAREFUL with a sharp hook tool and your bumper. It takes quite a bit of muscle to pull these out the first time and if you are not prepared when it suddenly lets loose you can really scratch your car, stab yourself or fall backwards. After the first time it snaps out it becomes much easier to insert and remove again if necessary. Everything else is easy. I could remove and replace in about 20 minutes after a few times of practice when the car is already properly set up on jacks. Also I did not remove the wheel well liners. Loosen the bottom of the liner and insert something to keep it pried open. Use and extension tool to remove the small screw thats behind and underneath the side marker lights.
I did it about six months ago following the thread in the DIY section.
It was easy. It took me about two hours to remove, clean radiators and re-install.
The hardest part is the headlights. Just make sure t get all of the screws in the fender liners
and underneath and don't force anything. Slow steady pressure.
The biggest challenge for me was the hose for the headlight sprayers. If you have these options, and your instructions don't show you how to deal with them, you may want to reconsider.
I had to replace one of my horns.... common failure for 2009... I did the repair from loosening it all up but could not get the hose off and therefore the bumper.
Peace
Bruce in Philly
Peace
Bruce in Philly
Just recently did this on a 07 4S as i was installing a 3rd radiator.
From what i recall.
1. Remove headlights using factory tool.
2. Remove side orange lights using a plastic panel popper.
3. Remove front lower light assembly by wedging a plastic panel popper on the innermost portions.
4. Lift plastic cover under hood at the front and remove 3 screws.
5. Using a metal pick tool, slide the metal spring clips(hard to see but youll see a small hole on the metal clip) located where the bumper cover meets the body. Pull these towards the center of the car.
6. Remove front left and right wheels, and remove the front most wheel splash guards (5 screws).
7. Unplug the main electrical connector located behind the passenger side splash guard.
8. Unplug the washer hose by removing the blue clip on the drivers side behind the splash guard.
9. Youll see a screw near the washer hose, that connects the bumper to the body, remove this and repeat on passenger side.
10. Go to bottom of car, youll remove about ten screws which attach the bumper cover the body/splash guards.
11. Bumper should come off but make sure all electrical connectors on bulbs are disconnected.
PS Thanks to Carrera Mike for the third rad instructions!
From what i recall.
Frustrating.
