Proper Seat Adjustment?
Old Mar 13, 2007 | 03:13 PM
SYMA's Avatar
SYMA
Question Proper Seat Adjustment?
Hello all,
Obviously some personal preference comes into play here, but what about any rules of thumb or what they might teach you at PDE's?
What is considered correct leg extension or bend in knees? What about arms and seat back angle/seat bottom height also?
Welcoming all replies.
Thx.
Old Mar 13, 2007 | 03:23 PM
kauai_diver's Avatar
kauai_diver
Straight to Video
For leg position: your knee should be slightly bent when you depress the clutch fully to the floor.
For arm position: you should be able to hang your wrists over your steering wheel.
For ride height: you should be able to see the tops of both humps of the headlights.
Personally I like my arms stretched out a bit more when I'm on the track. When cornering hard or into a hairpin its easier for me if the steering wheel is a bit further out. But your elbows should definitely be bent slightly when gripping the wheel to avoid fatigue.
Old Mar 13, 2007 | 03:30 PM
CBnAT's Avatar
CBnAT
Make sure you can easily depress all the pedals all the way to the foor without any mats. If it feels almost uncomfortably close compared to street driving you should be close to the right set up.
Old Mar 14, 2007 | 09:36 PM
bdmason's Avatar
bdmason
It is very close to being the same information I would give you if you asked me for the correct way to race a bicycle. Thanks for the info. I wasn't sure about where to position myself in a p-car
Old Mar 14, 2007 | 10:47 PM
Jim (CIA PCA region)'s Avatar
From Cass Whitehead @PDE:
1) Seat height all the way down, so long as you can see over the top of the instrument cluster
2) Seat fore and aft to the point where you'd have a slight bend in the knee remaining if the brake were all the way to the floor, check with clutch and left leg, too, slight bend remaining.
3) Steering wheel up down to where you can see the instruments.
4) Steering wheel in and out, out to the point you can hang your hand over the 12:00 spot on the wheel. The wheel should touch between your hand and where your watchband would be. Make sure your shoulders are all the way back in the seat, most people have a tendancy to hunch forward a little. For all but those with really long arms, this probably means the in-out will be all the way out (towards rear of the car).
5) Seatback rake, where you like it, so long as you can drape your wrist as in #4.
6) Hands 9 and 3 o'clock, NOT 10 and 2. The bulges at 10 and 2 are thumb rests, not for your hands.
HTH,
Jim
Old Mar 14, 2007 | 11:08 PM
SYMA's Avatar
SYMA
Thanks everyone. I really appreciate it. I believe I have it dialed in nicely.
Old Mar 14, 2007 | 11:09 PM
JFScheck's Avatar
JFScheck
Cass rocks!
Old Mar 15, 2007 | 12:19 PM
Le Chef's Avatar
Le Chef
The only real difference seems to be seat height. For road I prefer the seat so I can see the fender tops. For track I can see the benefit of having the seat as low as possible. If you have memory seats you should be able to program one of the settings for a road and another for track.
