Coolant temperature running high.
Old Mar 2, 2007 | 09:10 PM
TripleInboard's Avatar
TripleInboard
Default Coolant temperature running high.
Nevermind guys, I goofed on reading the instruments.
Old Mar 2, 2007 | 09:15 PM
Bum's Avatar
Bum
The manual states that the temperature will rise if the car is put under a greater load than normal. Is it getting warmer where you're located or are you driving the car in a more than spirited manner? Also, are your carrying more things in the car than normal. The key word here is "normal". Any changes to your normal routine may explain this scenario.
If not, a check of your records for the last coolant change or a check for coolant level may be the standard starting point.
Old Mar 2, 2007 | 09:17 PM
TripleInboard
Oops, I meant oil temp and not coolant temp. I guess everything is running ok then. Sorry about that.....
Old Mar 2, 2007 | 09:24 PM
Bum's Avatar
Bum
No problemo. I'm still getting use to some of the information myself, but it's great to have a place to shoot off a question and get a quick answer anyway.
