Front License Plate Question on European Delivery
If I opt to get my 997 on the Europen delivery plan, does Porsche in fact install a license plate on the front for use during my stay there in Germany?
We do not use front plates here in AZ and I'd not be overly happy having unneeded holes left in the front bumper due to that European requirement if it exists.
Yes, the bumper will be drilled with a bracket and European front plate installed...you have no choice.
When I did Euro delivery on my Cayenne S they zip-tied the plate to the front grill so no holes were drilled. You can see the difference in the photo compared to the standard Euro plate on the C-S to the right. Of course it could be harder to do this properly on a 997.
Poseur
If you arrive with a special fixture in mind you can intercept them from putting holes in there. But, the Europeans are strict about having a plate in the front so you need to make sure your design will pass muster with them. I would suggest that you spend a little time at the dealership in the states first to come up with a solution, and present it to them in customer care as you arrive. Get there early and discuss this with them up front. As an American, they will be providing the temp. tag for you, whereas Europeans, when they arrive, usually have their plates in hand when they walk in the door. When they hand their plates to Porsche it is assumed that they will follow the usual convention for European plate display. If you have no tiptronic or X51 car there is another method you can try that puts the plate in front of the center radiator cutout that I have been working on. But it is not a simple solution yet.
Skene, puts it in the right place. Very clean, then forget it. No tickets or stops. Ever have a glass of wine with dinner? You don't want a reason for a stop!
