Best WAX For Guards Red ??
I use Z5 Pro and the gloss and protection on seal grey are astonishing. Wait a minute....just noticed you are in Dade...Sunshine. Red's tend to be very prone to fading, use Z5 Pro, it contains sunscreens to keep UVA and UVB damage to a minimum.
For Guards Red the best wax out there to give it the deepest shine is Pinnacle's Souveran Wax, hands down.
Definitely much easier to use than Zaino, hands down.
Most waxes will start to deteriorate very quickly in the hot sun. The oils start to migrate out, you will then always pick-up more dust or dirt and if you are near trees, the pollen will stick like flypaper. Then, the protection starts to also loose its effectiveness.
Waxes do look great, but they HAVE to be maintained and more often in hot environments.
Sealants do not have the problems waxes do, last longer, easy to maintain. More and more sealants are getting closer to a wax look. Some sealants though still will give off a very steril/plastic-wrap look.
Zaino Z5-Pro and or Z2-Pro with Z8 Grand Finale QD spray has been a very good match. Zaino is also going to be releasing a new AIO (All In One) and a Clear Sealant that you apply and walk away, no rubbing/buffing.
The best and longest life for Zaino is to mix it with the ZFX additive.
Zaino is applied very very thin. As thin as possible. Also it can be layered as most sealants can, but some cannot due to the solvents used in them.
There is Klasse, Rejex, Wolfgang, Blackfire, Menzerna FMJ, Meguiars and more in the sealant lines.
Souveran is a very nice wax and used it often, but as much as it will make your finish very deep/wet looking, the oils will attract dust like mad. I find that I not only have to wash a finish more often that is exposed to lots of sun, but also clay it to remove the darn debris that just will not let go after washing.
Most people will go with a sealant since it's easier to maintain, lasts longer and look very nice.
Those wanting wax will be washing it more often and maintaining it to try to kep dirt at bay. Great for concours events! Hell, you can even top a sealant with a wax if going to a Concours event then, later, wash off the wax with a Dawn wash leaving the sealant intact for the most part.
There are many waxes, some costing very big $$. Most waxes have the same main ingredient which is carnuba and some add bees waxes as well. Then, the oils are added for depth. The more exotic the oils, the more $$ you'll pay. No need to spend lots of cash for a wax as most are subjective anyway. Some waxes not only contain the above aforementioned, but some have added polymers to last longer than std waxes and to compete with sealants.
If you are not going to be waxing or maintaining this every weekend, then I'd choose a sealant. If not, wax away Danielson.
You can gain more ideas and reviews etc on several other forums such as Autopia.org, Detailersclub.com and a few others.
Regards,
Deanski
Car show trophies:
Zaino: 0 for 5
Mirror Glaze: 3 for 4
