Car is surging on freeway at 3k rpm.
I have noticed that at freeway speeds (between 50 and 70), and in any gear, that when the engine is moving between 3,000 and 3,100 rpm that the car will surge forward despite applying no or small throttle advances. It is getting annoying as that is a common RPM range to be cruising at on the highway. It is enough of a surge that it pushes my head back if I am not anticipating it. I am running 93 octane, car is a 05 997 non-s with manual transmission.
Is there some kind of variable timing system that advances itself at that RPM? If so I think perhaps one of the solenoids that advances the system is not working as seamlessly as it should be.
Newbies Hospitality Director
http://www.porsche.com/usa/models/91...detail/engine/
Possibly a combination of variocam (though at 3100 it's early) and the DME which thinks you're in crusie mode (do you drive sedately/smoothly most of the time?). Try doing some hard driving for 10 minutes changing gears at the redline and changing down 3K rpm and seeing if that has an effect. If not get the dealer to clean out your DME and start driving a little more aggressively maybe.
