Dension Gateway 500 iPod Adapter Arrived Today
#46
Originally Posted by larrytrk
Better to have an ignition switched connection than a direct battery conection or drain may be increased when sitting off. We already have enough drain at rest!!
I think the always on power is important to make sure the device is ready when the MOST bus start so that it is properly recognized.?.?.? The NAV drive also gets always-on power.
#47
Originally Posted by MyEmily
Larry, Thanks for reminding me about that. I forgot, it's not an amp where it require a trigger wire to turn it on. To wire an amp, it's best to wire direct and not thru tap. Ground loops etc....
Rick thanks for your inputs. I guess you have been playing around w/ the DICE. Just to let you know, I was not a fan of hooking up an IPOD to the PCM. After reading your posts, I'm just waiting for the group buy to get a better discount. I had bought a lot of songs thru itunes. Too lazy to rip it to MP3. The DICE will do the trick. Those FM transmitter sucks. Do PCM have Cassette? AAC sound alot better than MP3..
DICE is affiliated with Dension USA, a completely different company than Dension. Check out www.dension.com and www.densionusa.com
#49
Originally Posted by rickhuizinga
And so far, there are no bugs. I'm keeping my fingers crossed as I've only used it for one day so far. The song titles do update when changing tracks. The song title is displayed on the PCM, but not in the instrument cluster. I.e. The same way that the PCM works with a CD with text information: the intrument cluster just shows track #, and the PCM shows the CD text.
My NavTV doesn't automatically advance the track number or title. If I manually skip a song, the track number and title will move to the next song. However, if I just let the system play a sequence, it's always stuck on the first track.
#50
Please note that this isn't the DICE unit. Rather it is the Dension unit from Europe. I purchased it from www.maxcount.de. The DICE unit appears to be a completely different design that has yet to be released.
Hey Rick:
Did you check your MOST bus for the proper connectors prior to ordering the adaptor, or did you just get lucky? <g>
I was wondering about the easiest method to check the connectors without disassembling the entire electronics bay shroud.
Also, I see that maxcount removes VAT from the price (419 Euro - VAT); I'm assuming that the shipping offsets the VAT removal, right?
Looks super and thanks for the writeup. I'm in Munich the rest of this week but will order when I get back to the US and check my fiber end connectors...!
-don
#51
Originally Posted by dstrimbu
Hey Rick:
-don
-don
#52
Its not clear if all components in my car used Yazaki connectors, or just the NAV unit. The only way to check is by removing the component and looking at it.
As for price, it was 361,21EUR plus 25EUR for shipping.
#53
where did you tap into MOST line. Did you just unplug the nav plug and splice there? Did you have to remove the NAV unit to gain access? Looks great!! I see where 12 volt unswitched is necessary! I will have to check the extra CD player plug for power and ground. Don't know if I can wait for group buy!!!
#56
Rich,
You mentioned:
"On another board, I posted a description of the operation of the Gateway 500 on the CDR24 - the operation on the PCM is the same except you will be using the PCM menus to control the Gateway 500 using the CD changer menu and commands:"
Do mind letting us know on what board? I have GT3 coming with the CDR24 and am interested in the gateway 500 fxn with this headunit.
You mentioned:
#57
Originally Posted by Bob/Ft. Worth
e-mail eric at bumperplugs.com for details of a group buy he will be sponsoring
What is also interesting is Multimedia adapter with audio for Porsche PCM 2 that maxcount.de is selling. From the description, looks like video could be shown on the pcm screen.
#59
Is this group buy happening now?
If so where is the link? I have sent off a few requests for group buy info to various sellers in Europe, so far no go. I hope to get a response from another seller tomorrow. Will put a post up if I am successful in getting an interested seller. If Bumberplug is already doing it then great, I'm in!
#60
Originally Posted by CoGT3
Rich,
You mentioned:
You mentioned:
I also copied the text into the post that you responded to.
