First gear Problems
Old Jan 3, 2007 | 02:15 PM
vegascomedy's Avatar
vegascomedy
Default First gear Problems
Have noticed since I got my car that sometimes I have problems getting it into first gear. I am talking about when the car is completely still.
Just reached 2k miles last night. Was sitting at a stoplight and put the car in neutral so I could take my foot off the clutch for a second.
Couldnt get it back in gear! This is not the first time this has happened.
Never had this problem in my 02. Is there something wrong with my transmission? anybody else having these problems?
Thanks in advance!
Old Jan 3, 2007 | 02:18 PM
JMAGOLAN's Avatar
JMAGOLAN
First gear is occationally "notchy" on mine, too. I notice it more when it is cool (50s or less). Do you have a short shifter? Those are known to be stiff when the temps drop.
Jerry
Old Jan 3, 2007 | 02:21 PM
1999Porsche911's Avatar
1999Porsche911
That is not normal on a warm tranny and I would insist that the dealer correct it, Be assured that they will probably try to get you to accept this as normal for the car, and you may have to push to get it fixed.
Again, it is NOT normal and the tranny should easily slide into 1st gear when moving slowly or at a complete stop. They will probably tell you that you have to put it into 2nd gear before 1st, and this is also not true. Putting it in 2nd first may help, but should not be necessary.
Old Jan 3, 2007 | 02:40 PM
Stephenkng's Avatar
Stephenkng
You only have 2K on the clock, give it a couple more thousand miles. It will loosen up.
Old Jan 3, 2007 | 03:27 PM
Coochas's Avatar
Coochas
Michael...
I rarely experience this problem as well however the car definitely did this much more frequently when it was 'younger.' It's now over 250 hours running time and this notchiness thing is almost extinct.
If it's happening frequently, bring it in,...otherwise I would give it some time.
Old Jan 3, 2007 | 03:28 PM
The B's Avatar
The B
Over time my car began acting like that, then the shifter cable snapped (at @ 20k miles). Maybe have it checked out...don't let limp stick happen to you...
Old Jan 3, 2007 | 03:44 PM
OCBen's Avatar
OCBen
Originally Posted by Coochas
It's now over 250 hours running time...
(Let's see now, taking Dave's average speed of 140 mph, multiply that by 250 hrs....)
Wow Dave, I didn't know you had 35,000 miles on the clock already!!!
Old Jan 3, 2007 | 03:53 PM
Texas993's Avatar
Texas993
Mine finally loosened up at 2500 miles. Sport shifter.
Old Jan 3, 2007 | 03:54 PM
Matt(inMA)'s Avatar
Matt(inMA)
Not in MA anymore
I had the exact same thing happen twice in the first 3K. I now have 8.5K and it's never happened again.
Matt
Old Jan 3, 2007 | 04:08 PM
1999Porsche911
I would have the dealer look at it now so there is NO question that the problems exists. Otherwise, some dealers will not cover it, claiming that you damaged the syncro's by shifting improperly.
JFScheck's Avatar
JFScheck
Sport Shifter - lossened up around 2,500 as well - now even when cold it's not too bad (38 degrees out the other day before the engine was cranked) but once warmed up it is soooooooooooooooooooo great as was about ten minutes!!!!
Old Jan 3, 2007 | 04:13 PM
dstrimbu's Avatar
dstrimbu
Yep, miles will do it. At 6,000 on the clock, the notchiness in my shifter is gone. First can be tough in general with a cold trans, but should be like buttah when it's warmed up...
If it won't go into 1st, try selecting second, then back to first. That'll work, too.
Old Jan 3, 2007 | 04:22 PM
Frino's Avatar
Frino
No problems getting into 1st (even when cold) or notchiness with sport shift (7K on the odo).
Old Jan 3, 2007 | 04:42 PM
Coochas's Avatar
Coochas
The sad thing is that my average speed is only around 20-something mph as I live and work within a city....I live for the weekend roads!
Old Jan 3, 2007 | 04:50 PM
ELUSIVE's Avatar
ELUSIVE
I have the sport shifter and have this same exact problem.
Only have 600 miles on the clock and the car is stuck in the garage because of all of this Colorado snow.
Sucks!!!
