Choppy throttle
Choppy throttle
Hey everyone. Still newbie to these forums so any words of wisdom would be most appreciated. I just got a new 997S around 4 months ago. I have been extremely careful in the breaking in period. I observed the 4000 rev limit as suggested for the first 1000 or so miles, but after 1500 I was moving around all rpm's (nothin crazy/max 5000) engine breaking hitting the full spectrum on revs all around as suggested by many kind posters...
Earlier, under 500 miles, I experienced some jerking in the throttle (ie uneven acceleration when slight gas applied). I posted this on one site and it was suggested that it could be bad fuel or not warming up the engine. No issues through 2200 miles.
Earlier today, took a 300 mile drive and the last 50 I experienced the jerky throttle once again. I had a half tank of fuel and put some fuel injector cleaner w/ a top up of 93 Amoco gas and still had the jumpy throttle. It felt like the fuel line was getting choked or something but what do I know...
Any suggestions???
Any suggestions???
I have the same issue and it is more pronunced in the "sport mode" and funny enough it is especially worse when I use a 50% blend of 100 Octane Shell racing fuel mixed with 91 Octane fuel.
Search the forum for "throttle body" and you'll get some info. Here is my post after I experienced the same problem. Do you have an '06 or an '07?
I now have not had a problem after the dealer performed this fix. Goodluck.
"Final Verdict" - Maybe
I spoke with my dealer today and they claim they inspected the car and the cars computer and PSM system and found no error codes. They visually inspected the vehicle and performed "the throttle body repair" and test drove the car on 3 seperate chances today and the car was fine.
I will pick up the car Tuesday and report back. Maybe this throttle body problem is hit or miss on cars.
I was not expecting Honda reliability, but my 40+ year old P-car requires less attention/1000 miles than this car so far.
I get it every once in awhile. I am still unsure as to why. I get it after I fill up, I get it when I'm almost empty I recently got it at 1/2 tank. I get it with sport mode on/off. I get it with different brands of gasoline. Usually will go away after the car sits for awhile.
I took it to my dealer and of course it ran just fine. It is more frustrating than chasing a rattle in the dash.
I wonder if 91 Octane ( the highest we can get out here) is responsible?
Guest
Posts: n/a
Sounds like it could be related to the hesitation issue that's been actively discussed in this forum; here's two threads of many:
https://rennlist.com/forums/997-forum/277930-my-car-acted-up-big-time-hesitating-and-very-jerky.html
https://rennlist.com/forums/showthre...ght=hesitation
https://rennlist.com/forums/showthread.php?t=277930
Guest
Posts: n/a
Originally Posted by Holli82
thanks for the link. I must say I've reviewed all of the links on the 997 forum and on other sites as well. Bottom line is there is no one clearly defined easily reproduceable set of factors that I've been able to determine is the cause. More importantly, there is no well defined "fix" regardless of the cause. Maybe the throttle body fix is it.
