What does your steering wheel feel like at 70 mph
Originally Posted by OCBen
Thanks Pug. I'll take you up on it, if you let me buy the beers.
BTW Ben,....I can put away quite a few thanks to my new third leg (thanks again Jeff - I still can't believe he could recall so much just by using the urinal next to mine).
Originally Posted by Pugnacious
Ben, I look forward to it! I'll have to trade the beers for diet coke! I think the apple cider is a year round thing.
Originally Posted by Coochas
...BTW Ben,....I can put away quite a few thanks to my new third leg (thanks again Jeff - I still can't believe he could recall so much just by using the urinal next to mine).
"WElcome to Jamaica, Now have a Nice DaY."
So he sized accordingly.
You might have an out of round tire if you have balanced them all and it still does it. It seems the dealer could figure that out. I have in the past (not with a Porsche) taken cars to frame shop who checked all aspects of the car and the tires. Most big cites have shops that deal with high performance cars.
This would drive me absolutely nuts, Porsche's just don't do that.
PS, your in Colorado, Discount Tires have always been good for me
Thanks everyone for the replies. I certainly didn't think it was normal...
The tires are Pirelli's and I'm running the pressures listed for the tires.
I didn't realize how bad it was until i got into my A4 this morning and drove on the highway and steering wheeld didn't move a mm.
I think i'll bring it in again and have the tech go with me for a ride....
Yeah I had a problem like that in another car of mine, it turned out that the front two tires (FWD) had blisters 'in' them from driving the car somewhat vigourously. Turned out the tires were a 'bad' batch and I got them replaced
The Penguin King
I've also had the experience in other vehicles of a bad tire causing this. I'd check the balance first, but if that doesn't fix it, you probably have a tire problem.
i was up to 110 yesterday on the highway and it was smooth as silk.
i had some major issues at similar speeds in my cayman s and it was an out of round tire. go to a shop that specializes in balancing and is using a hunter balancing machine. have all 4 tires road force balanced. my bet is at least one of them is bad. You can also have them take the tire off and make sure its not the rim. the tech's experience with the machine is almost as important as using the proper equipment. I had my OEM PS2's balanced over 5 times before it was done right and stuck. good luck, and if you need help finding a shop go to the hunter website.
I had the same problem with my Cayman... Took it to the dealer and they said they rebalanced the tires... The issue remained... I finally took it into a shop with a Hunter machine and had all 4 tires rebalanced... Wobble gone!!! You would not believe how far off they were from the factory... I'm sure all the dealer did was wave the magic wand then told me it was fixed...
Originally Posted by ELUSIVE
70 mph on a smooth highway.
What does your steering wheel feel like?
Is it perfectly still?
Mine has a wobble in it. Took it to the dealer. They balanced the tires and said the alignment was ok. Still wobbles at 70-80.
Wonder if this is what you are referring to as wobbling? Anyone has any thoughts? Do I need alignment. I have two brand new front PS2 tires.
Guest
Posts: n/a
