Top speeds in each gear
I remember seeing a post a while back that showed the mathmatical top speeds for each gear for a 997 S. Does anyone still have that link?
Thanks,
Ron
Thanks,
Ron
From R&T article:
With my car in Sport mode, the digital speedo showed 153mph, on the hard rev limiter, at the top of 5th gear.
But then, maybe I just dreamed this?!? ;-)
Originally Posted by Joee
Might want to calibrate the speedo...they usually read a few mph higher than the actual speed. Given that things look pretty close to the R&T article.
MC
Originally Posted by Coochas
From R&T article:
Somehow, I thought the top speed was 187, but 182 - 187 - either way I'll never see either.
I am a new rookie owner, 2780 miles x 2.5 months.
This article helps me to recollect my first "sport mode" freeway entance after breakin.
I only remember that in what seemed like a blink of an eye, I was doing 115 mph. Exhilarating, amazing, frightening quick. Regardless, I could'n't remember what gear that I was in- had to be 4th.
I plan on attending the PDE this spring.
Originally Posted by Edgy01
Top speed is truly 182,--or thereabouts. I got close, and the car had plenty of pull, in that range, even in 6th gear.
Hell, I've done 140 in my Mercedes, so I'm embarrased I haven't been able to go faster in the 911 yet. However, they changed the race track up here which slowed down the straight so I just can't manage to get much faster at this point. It also doesn't help that the track has a crappy surface, so if you overcook it you'll be on VERY bad conditions which aren't very forgiving to cars going 100+. so that tempers my desire to push it harder.
