NEW Braided Brake Lines
The TRG and Goodridge developed stainless brake lines are through testing and good in stock. Set of 4, $189 per car, an exact fit for factory replacement.*
Each line is teflon coated, then gel coat sealed with blue tint. They perform and look great. Designed through The Racer's Group and Goodridge (the Formula 1 components supplier) partnership, these lines have high heat tolerances, and United States Dept. of Transportation (DOT) approval.
-Reduce pedal spongy feel
-Increased heat tolerance
-Increased brake pedal modulation ability at temperature
-Accepts all DOT 4 fluids, including SRF
-Protects against track and street debris punctures
-Lifetime Warranty
Also available for the Cayman, Boxster, and 996 (all).
*Will require a brake flush, we also carry fluids. (shameless plug here).
pics...
