997 Oil Change
997 Oil Change
I spend most of my time on the 928 Form, but my neighbor came to me with this question that I could not answer.
His father was changing the oil on his 2006 997 for the first time and when he had drained all the oil he only got about 3 Qts out. The plug that he used to drain had some sort of shaft and a spring attached to it.
Was he draining the transmission or the pressure relief? He said that this plug was the only one he could find on the crankcase. As far as I know this engine does not have a true dry sump, but would the faux dry sump prevent all the oil from coming out?.
Can anyone shed some light on this?
'79 928 5 Speed
Beck Spyder
'79 928 5 Speed
Beck Spyder
So the plug in the picture is not the oil drain plug?
So this guy did his oil change wrong?
i guess ben was too modest to link his own post
Newbies Hospitality Director
Jeff, that is the funniest comment I have seen on the Forum in weeks!
