TSB 3005 Bulletin
Vehicle Type: 911 Carrera (997)/911 Carrera S (997)
Model Year: As of 2005
Equipment: Manual transmission (G97.01)
Concern: Noises when engaging the clutch pedal.
Information: In the event of a customer complaint regarding the above-mentioned concern, please refer to the
attached advance copy from the Workshop Manual on the topic "Clutch, actuation" which will be
published approx. in the middle of in POSES.
The Workshop Manual contains specifications and information on lubricating the clutch pedal, bracket,
and clutch power spring. If there are noises in the clutch pedal, the recommended grease listed needs
to be used.
Attachment: Workshop Manual ’300519 Removing and installing the clutch pedal’
Technical Information 911 (997)
4/05 3 3005
to be used.
4/05 3 3005
