Coloured Wheel Centres
Old Aug 11, 2006 | 10:41 PM
Pincomar's Avatar
Pincomar
Default Coloured Wheel Centres
My new, very nice, coloured wheel centres arrived today for my new C4S. I see how they attach to the car. To remove the old ones, is there any other technique but insert bent coat hanger and pull?
Grateful for any advice.
Will post pictures when it is done.
Mark.
Old Aug 11, 2006 | 10:56 PM
STATMAN's Avatar
STATMAN
There is the pad Porsche Hubcap Removal Tool for $39.95
http://eagleday.stores.yahoo.net/potiac.html
Old Aug 11, 2006 | 11:44 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Save the $40 and do the coat hanger trick. If they don't come out easily it might take removing the wheel first. Then, just give them a little tap from the back. I don't imagine the center caps come with the security devises from the factory.
Old Aug 12, 2006 | 05:08 AM
Tedder Bear's Avatar
Tedder Bear
Needs a Chuckle
Bought my colored center caps after buying the car. You don't need to buy the tool. Had no problems popping out the old center caps and replacing them with the colored ones.
Old Aug 12, 2006 | 01:44 PM
Pincomar's Avatar
Pincomar
Default You are absolutely correct
Bent a wire coathanger in to an L shape and they popped right off. Two minutes work. Rather too easy actually. Very little to stop a knowledgeable thief? Just like the headlghts?
Thanks for your help.
Mark.
Old Aug 12, 2006 | 02:20 PM
jhbrennan's Avatar
jhbrennan
Mark.
If you don't want to use a wire device you could use this as the time to remove and completely clean the wheels and then add a coat of Rejex. With the wheels off the center caps pop right off. I know, lots of extra work.
Old Aug 12, 2006 | 02:45 PM
MJones's Avatar
MJones
I used the end of the corkscrew device on my Swiss Army Knife once
