Attempting to install a child seat in the rear of my 997.
You can close the flap enough for it not be noticeable immediately. Then again, folks usually don't do much with the parcel shelf in the back often.
If you are careful, you can get away with cutting only for the flap to fold and nothing more. No piece should be cut off from the carpeting completely.
I installed both and they fit great with little to no movement.
For reference I only removed the Velcro rear seat bottom. (I tried to remove the rear seat back but one of the torx bolts was stripped so I figured I would just test it with the seat back still installed and it fit great!)
i own a 2010 c4s from I understand the c4 has a narrower seat bottom than the narrow body so you should have no issues fitting either of those britax seats in your 911 wb or nb
Hope this helps anyone looking to figure out the car seat situation.
997.1 Coupe
Hey - I’ve just bought a 997.1 Coupe after scrolling many threads thinking I’d be able to install a car seat but so far unhappy with the fit of any, including the Porsche seat direct from them!
Do all of the U.K. 997.1s coupes have an anchor point in the rear? Looked at the carpet for the marking but can’t seem to see anything indicating it’s there.
Thx.
Thx.
I did find this part: 997-803-721-00 which is available here: https://www.gaudinporscheparts.com/o...waArGoEALw_wcB
Does anyone know if this works, if I need any other parts to install it? If I have to cut wholes in the carpet piece behind the rear seat backs / in front of the rollover bars?
Thanks so much in advance!
There was no anchor point in the U.K. Coupe which could be found by a specialist. I ended up selling the 997.1 (very short lived ownership) for a Macan Turbo, just couldn’t get comfortable with the kids safety.
