Trip information in OBC vs. PCM
I've read the manual, but I still don't have a good idea what the correlation is between the trip information stored on the On-board Computer vs. PCM. I'm assuming that the OBC information is reset via the menu in the center gauge. Is the trip information in the PCM totally independent from the OBC trip information. Does the PCM reset command reset all three types of trip information simultaneously (continuous, since hh:mm, and <the third type whose name I can't remember right now>)?
Thanks,
Anthony
Thanks,
Anthony
Thanks,
Anthony
Thanks,
Anthony
In the OBC you can reset indivdual perameters ( (av speed,mpg,distance)
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Originally Posted by MJones
PCM trip info (continuous, since, OBC) reset is global for all perameters.
