DIY Oil Change in the 997
Old 08-16-2009, 05:20 PM
  #106
OCBen
OCBen's Avatar
Originally Posted by MyEmily
Is the 997.2 filter interchangeable with the 997.1? I like the idea of a smaller wrench. Also does the car have to be level to evac all the oil out? can it be on a small incline?
The filter cartridge should be the same as the one they've been using since the 996. Just ask the parts counter guy if the part number is the same.
Yes, to maximize the amount of oil drained you'll need to have the car as horizontal as possible, inasmuch as the oil pan has a flat horizontal panel on the bottom. You don't really need to jack up the car at all. If you have a sloping driveway you can position your car so it's horizontal inside the garage while you leave yourself enough room to crawl underneath from the back and slide the drain pan underneath. Ask Edgy and PaulSpeed how they do it.
Old 08-16-2009, 05:55 PM
  #107
Edgy01
Poseur
Edgy01's Avatar
As a Porsche guy I'm a bit **** (you think?!)
I have a perfectly level garage and drive. Thus, to get access to beneath the engine I have to get them up a little. I use a pair of floor jacks. Once I get the bolt out and the filter cartridge cover off, I lower the car back down over th used oil collector(s) and eek out the last of the old oil. Then, I jack it back up again to access the bottom of the engine, put things back together, and then clear everything out of the way, drop the car, and then refill with oil.
Old 08-16-2009, 06:14 PM
  #108
vexed
vexed's Avatar
The p/n is 94810722200, I read somewhere it is the same filer as the Cayenne V-8 and the local parts department confirmed it. There is a gasket that is sold separately.
Old 08-16-2009, 10:00 PM
  #109
gray911
gray911's Avatar
Suncoast throws in the gasket for free if you buy the filter.
Old 08-17-2009, 05:33 PM
  #110
helispud
helispud's Avatar
I think I'm going to epoxy in a small magnet onto an extra aluminum oil plug and put it in during my next oil change. It will be interesting to see if anything shows up on it. I miss that from the older 911s//930s.
I wound up using JB Weld and put a super magnet on the drain plug. I tested it beforehand in my climate chamber (i.e., freezer, and then oven) and it came through unaffected. There was nothing on the magnet after an engine oil change cycle.
I found a magnetic drain plug for sale at LN Engineering http://www.lnengineering.com/drainplug.html
They also sell an adapter so you can use a spin-on oil filter rather than the Porsche filter in a plastic cup.
Old 08-17-2009, 05:43 PM
  #111
helispud
helispud's Avatar
Maybe I have freakishly long arms, or as some on this forum have said, a regular non-PASM C2 has the clearance of a SUV, but I'm able to reach the drain plug and filter without jacking the car up.
Old 08-17-2009, 06:20 PM
  #112
gota911
Newbies Hospitality Director
gota911's Avatar
When you are standing straight, can you scratch your knees without bending over? If so, then yes, you have freakishly long arms.
Old 08-17-2009, 09:50 PM
  #113
helispud
helispud's Avatar
As my fingertips are well above my knees... my C2 has the clearance of a SUV.
Old 08-18-2009, 12:41 AM
  #114
luisimo
luisimo's Avatar
Great thread!
Thank you.
Old 03-20-2010, 05:58 PM
  #115
Alfaguy2
Alfaguy2's Avatar
and the other 3 quarts or so that you have to remember to remove from the central engine drain plug...
There are two oil drain plugs?? - any pics of this ones location?
Old 03-21-2010, 04:45 PM
  #116
Alfaguy2
Alfaguy2's Avatar
Well??
Old 03-22-2010, 04:30 PM
  #117
Minok
Minok's Avatar
Originally Posted by Alfaguy2
Well??
Different engine.
Old 03-22-2010, 08:32 PM
  #118
Alfaguy2
Alfaguy2's Avatar
Originally Posted by Minok
Different engine.
OK thanks - should have read the whole thread - great work OP thanks very much. I never realized there were such big differences between the 997.1 and 997.2 engines.
Old 05-06-2010, 01:27 PM
  #119
997, esq
997, esq's Avatar
Just a couple of notes I wanted to add to this excellent thread:
(1) It sounds obvious, but be sure to turn the drain plug and oil filter housing the correct counterclockwise way. It is easy to get turned around when working on your back, and to turn in relation to the ground rather than the car. If you use a socket wrench, you can make sure it is turning the correct counterclockwise way before going under the car.
(2) If your drain plug becomes stripped from being over-torqued (it happens easily bc the plug is soft), then use a screw extractor as described in these threads to remove the damaged plug:
http://www.renntech.org/forums/index...=3308&hl=sears
https://rennlist.com/forums/996-foru...ped+drain+plug
We grinded the end off a large screw type extractor from Sears in order to get a good fit, banged it into the drain plug with a hammer, and extracted a stripped bolt easily. As described in the above threads, other extractors also will work. For a replacement plug, I had an extra Porsche plug on hand. There is apparently a magnetized Raby plug and some other options available that are less succeptible to stripping, although I understand there is some benefit to the soft plug because it deforms instead of the oil pan.
(3) Regarding the engine air filter change, do not remove the air box from the engine. Rather, as described by Edgy elsewhere (do a search), disconnect the air intake hose, pull up the oil fill tube, pull up the air box (wiggling a bit), carefully rotate airbox so that the box remains in the engine bay and you have good access to the bottom of the air box, use an alan key or hex screwdriver to remove the 8 hex screws on the bottom just enough so that the two parts of the box can be separated, remove the old air filter, clean box with a damp cloth, replace new filter, and reverse the process to reconnect the air box. No need to disconnect the MAF sensor plug, etc.
(4) If you have any problem with the removal of the oil filter housing using a non-Porsche removal tool (I had a plastic No. 7 oil wrench that didn't seem strong enough in light of the unduly high torque of my oil filter), you can use one of those strap oil filter wrenches to remove the filter.
(5) I think dealers habitually overtighten things. Not only was my drain plug partially stripped, but I noticed the hex screws on the bottom of the air box were a bit deformed as if someone had used a power screwdriver with too much vigor, and the oil filter was on unnecessarily tight.
(6) In general, I found doing a service myself to be rewarding and pretty fun. At my billing rate, it probably makes more sense to pay someone to do these things, but I would prefer to do it myself. Also, I can make sure everything is torqued correctly.
Thanks again to the late OC Ben for this thread and others for their input.
Old 05-15-2010, 12:06 PM
  #120
Musclehedz101
Musclehedz101's Avatar
In case you didn't see my post, in North Texas (Park Place) is running a great special for new customers $129.00
https://rennlist.com/forums/general-...ml#post7572708
Quick Reply: DIY Oil Change in the 997
