Car Waxing Problem
I have read a LOT of the posts talking about this and I don't remember finding the answer...so here goes:
How do you wax around the door and hood seams? More importantly, when you nick a piece of plastic with wax it discolors the plastic....how do you get that off?
When I notice that I've done that, I have successfully wiped it right off, but when I miss one and notice it a few days later, I can't get it out. As for the seams, I'm guessing there is just no easy answer; either people don't get right up to the edges, do it very carefully or pop the hood and doors, etc when they're done and wipe it off.
Thanks for any advice
matt
matt
When you say plastic do you mean rubber ?
The seals around windows etc. ? If so use a
detail brush or an old tooth brush and dip it
in (ready?) peanut butter. The oils in the peanut
butter break down the white chalky wax residue
and condition the rubber at the same time. I
also use a product for the plastic cowl
(in front of the windshield called Black Again which
works great. Its available at autogeek.net for $7.99
either one works fine.
Good luck
Good luck
Another trick to keep wax out of the door/hood seam areas is to stuff some thin cardboard in there--the type that shirts are packaged in.
Believe the Back To Black is made by Mother's and can be found at auto parts stores.
Also, check out OC Ben's links on polishing and waxing.
Thank you much! I'm going to try the peanut butter because it would make a fun story if it works. I have read OC Ben's posts, but I don't remember all what he wrote. It was very comprehensive and I seem to get self-induced ADHD when reading it...despite how informative it is. (Someone should write a 'Cliff Notes' version)
In fact, because of all you I now have an obscene amount of car detailing products.
With the 3M blue painter's tape, there's two sticky-ness levels - low and lower. Both work, but the low stick stuff pulls off after several hours with zero issues... it's labeled #2080 and has orange markings inside the spool... works like a charm! Get it at Home Dee...
Good luck,
-don
Good luck,
-don
Guys, don't waste your precious time taping off. You're not painting body panels, for crying out loud. The only time I use tape is when I'm color sanding a car to keep from accidentally touching a panel I already power polished smooth.
I read on the Mini forum a post by some guy proudly saying he spent close to an hour meticulously taping the entire car before waxing. ... Sheesh, what a waste of valuable time that could be better spent elsewhere. Poor guy is simply misguided. On the Mini there are quite a few plastic trim pieces especially around the wheel wells that can potentially get wax on them and get discolored with a whitish haze as Matt described. ... I haven't detailed my Mini yet, but when I get around to waxing it I'll just immediately wipe off any wax that gets on the plastic molding and then apply a little Vinylex to the area. In fact, although I had requested no detailing by the dealer, I was later told that at the vehicle distribution center they apply a quick coat of wax on all the cars (probably not a wax I would use). This explains why a few days after taking delivery my wife pointed out this whitish haze on the tops of two of the fender plastic trim that I easily wiped off and treated with Vinylex.
I haven't tried Aerospace 303 like Statman but I hear it's an excellent product. I'm going to order some someday but for now the Vinylex works just fine.
Oh, as for where have I been? I told you guys I'll be super busy for several weeks. Just bought a house a couple weeks ago and I'm going to do some major remodeling before we move in. Getting a few general contractors to submit their bids and getting permits from the city (will be removing a load bearing wall to open up some space on the ground floor). Even though the house is still fairly new (6 yrs old), we're gonna give the place a fresh contemporary makeover on the inside.
