Sport Chrono.....
Originally Posted by Persuader
On the Turbo yes the Chrono comes with overboost but as this is the non-turbo forum I presumed you were talking about the non-turbo Sports Chrono.
Personally, I have started leaving Sport mode OFF while driving around town as it is smoother from a start and easier to control in traffic. When I want to be 'sporty', I do prefer the sport throttle map better,...it increases the fun factor for me!
Originally Posted by Colm
Wrong
Wrong
Wrong
It changes the torque curve, which aids in acceleration.
Learned this, and the fun effects at Porsche's ice driving school
Wrong
Wrong
My personal opinion of devices on any car that change the throttle mapping (but give no real increase in power) are nothing but poseur gadgets and appear to people that don’t know the difference from being faster and feeling faster.
The shift in torque curve allows you to get the back-end out easier, and is therefore not a poseur gadget.
It's a tool, within a tool (Porsche), that requires expertise, abilitity and circumstance to appreciate.
The problem I have w Sport is that it can cause you to misjudge the available power you have to work with in a given gear and situation. When driving on the street, for example, I have enjoyed the rapid tip-in which Sport provides. On those occasions where I have needed more acceleration ie pulling out into traffic, I have then used full throttle only to find there was little throttle left. IMO,the standard setting is more linear and gives you better feedback as to where you are in your engines power curve. Whereas I loved it in my M3 (which is peakier and has 1000rpm more to play with), I do not use Sport throttle in my 2CS.
Colm, not being funny but how many different people do you need to tell you that there is absolutely no change in the torque curve, all it is is less throttle pedal required to achieve the same.
I think the problem is with the definition.
Read Pugnacious's comments carefully where he talks about torque shift, and what happens in lower gears. He has pretty much nailed it.
You might be talking about total power output, which is different from power delivery; and delivery is what my point was about and addressing, pretty clear from the context and examples.
So the power is different in lower gears if the torque curve is shifted through the s/c button, and it is not a useless gadget.
If you superimpose the torque curve with S/C on and off, it is my understanding (and memory) that the curve shifts to the right over some range....in my book that's a change.
Again, from the article above, this is how the throttle response changes:
Originally Posted by gpjli2
Sport throttle as used in the 2/4CS changes only the rate of throttle "tip-in" You step harder on the gas in standard setting, you get the same effect. More power for less foot movement in Sport with the trade off of less fine control. Full throttle is the same for both
I think that suggests you are essentially "floored" when the throttle is 50% down. The rest of the travel does very little. Since dyno runs which measure hp and torque are done at fixed engine speeds, throttle position is meaningless. I think GM used to do this in the early smog days, giving the cars about 80% throttle in the first inch of movement to make them feel more responsive.
It probably won't be long before Porsche includes meaningful power enhancement with the package, since it seems discriminatory to the non- tt and GT3 buyers.AS
It's amazing how one individual can have the wool pulled so far over their eyes! It's a shame you have to believe in factually untrue information. If you check with Porsche you will discover that at any rev level in any gear the power and torque delivery are identical regardless of the SC setting. How hard is that to follow?
The only thing that does differ is the rev level in relation to throttle pedal travel. Not the same thing at all as a power or toque shift.
From the 997 Prod Info Book
The driver can select a sportier setup by pressing the Sport button in the center console. A certain amount of comfort is sacrificed in this mode for the sake of sportiness.
The word “Sport” appears in the instrument cluster display as soon
as the Sport button is activated.
A modified program is utilized for the following systems in the “Sport”setting:
• Accelerator pedal characteristics
• High-speed cut-off
• Dash pot (load change damping)
• PSM (Porsche Stability Management)
• PASM (Porsche Active Suspension Management)
• Tiptronic S (optional)
A number of adjustments are made in Motronic when the Sport function is
activated. The electronic throttle characteristicis switched to a steeper setting
(only in manual mode with Tiptronic S).
This produces a faster throttle response to accelerator pedal movements to subjectively increase the spontaneity of the engine.
Can I see some torque curves please, s/c on and off?
If they are the same under both scenarios, then I'm incorrect! The curves shouldn't lie.
As for power curve charts which are taken at full power (throttle) being as Sport Chrono does not change a thing at full throttle (only getting there) the power curve for a given engine would be identical regardless if Sport Chrono was on or off over the entire rpm range.
