spare mounted
Old Jun 11, 2006 | 02:12 PM
Coochas's Avatar
Coochas
MMD...
Thanks for this info.
I am going to make a separate post using the emergency tire that I just got for my C4S rather than complicating this post with more part numbers etc. Bottom line is I don't think it fits in the boot!
-dave
Old Jun 11, 2006 | 06:22 PM
Coochas's Avatar
Coochas
BTW, for anyone wondering, the tire pressure for the inflatable spare is 36 psi. I just got this out of the 996 owner's manual.
Old Jun 11, 2006 | 06:28 PM
SilverSteel's Avatar
SilverSteel
Did you buy from the dealer or used parts place? Looks like the dealer, but wanted to be sure. Also, what's the total price out the door? thanks
Old Jun 11, 2006 | 06:35 PM
Coochas's Avatar
Coochas
I bought mine new from Sunset (www.sunsetimports.com): spare about 545 USD, jack 120, foam piece 35...something similar to this - all told, about 700 bucks. This said,... I think you can find these spares from wrecked cars for significantly less money. If you want it new, Sunset is probably the best price around.
Old Jun 12, 2006 | 08:55 PM
SilverSteel
Wowie-kapowie! Not cheap, but that's the price for peice of mind. I'll be contacting them and my local dealer to check prices. Thanks for the tip.
Old Jun 13, 2006 | 12:35 AM
MMD's Avatar
MMD
The jack is kinda nice. Nicely machined and crisp and a good chunk of aluminum alloy geometry. Almost worth a us$120.
Maybe if the engineer of the jack were to have signed his/her name to it, then a "work of art" perceived value would kick in.
Old Aug 6, 2007 | 10:17 PM
george_k's Avatar
george_k
Just got my spare and jack + foam insert today from sunset.
Question for you guys with spares - How do you have the spare fastened down?
or is it just left loose standing up in the trunk?
also, is there any particular place the spare tire information sticker is supposed to be attached?
George
Old Aug 7, 2007 | 08:14 AM
Frino's Avatar
Frino
I have driven with the spare left loose for the past year without incident. It fits nicely and stays put with a couple of medium size towels wedged in on either side of the spare.
I did purchase the Das Schild (www.daschild.com) trunk liner to add a layer of protection between the spare and the hood. I also purchased the Cargo Organizer/spare tire cover from the same place. It's great for holding the tire wrench, torque wrench, work gloves, etc.
Stickers? We don't need no stinkin stickers!
Old Aug 7, 2007 | 08:49 AM
elh0102's Avatar
elh0102
I recently bought a folding spare for my 997S, and it is p/n 996-362-020-03; don't know the significance of the last digit being 3 rather than 2. I have used it once, and it works great. The recommended pressure on the tire is higher than previously mentioned, 50 psi. As for the other parts to make a factory-like kit, I guess that's fine if one wants to spend the extra money. Mine fits fine in the front, and lying at an angle that puts it almost against the closed trunk, it's not going anywhere. When I carry it, I usually place a folded cloth on top of the tire, so it is actually in light contact and can't move. And I have a compact BMW jack kit that fits beside it, so it cannot shift laterally either.
Old Aug 7, 2007 | 10:30 AM
george_k's Avatar
george_k
thanks guys
I'll try the beach towel method - good for the summer at the jersey shore!
the sticker i mentioned came in an envelope taped to the spare.
looks like its supposed to go in the trunk, shows 41 psi as the correct pressure
for the spare and some warnings about speed, etc.
when I get a chance I wll post a scan of it FYI.
Old Aug 7, 2007 | 10:47 AM
george_k's Avatar
george_k
spare p/n I have is 996 362 020 03
sticker shown is for this spare
File Type: jpg
Old Jun 10, 2008 | 04:10 PM
Zoom007's Avatar
Zoom007
4th Gear
Originally Posted by Edgy01
Here's what I believe you need:
996-362-620-02 Emerg tire (996)
996-722-101-00 Wheel Insert
996-721-211-00 Scissors Jack
999-571-074-30 Mounting Bolt
999-361-521-00 Tire Bolt
996-361-411-00 Belt
Dan
I have sent these part numbers for a quote to Porsche of Fairfield. This is what I got:
Spare tire- $893.52
Wheel insert- $73.09
Jack- $247.64
Mounting bolt- $18.61
Tire boot- $8.03 (I think you mean this # 996-361-521-00 rather than tire bolt)
Belt- $ 34.29
How does it sound to you?
Old Jun 10, 2008 | 04:55 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Spare tire- $893.52
Jack- $247.64
Belt- $ 34.29
You might do better with Sunset Porsche (Portland, OR)
