Anything effective against "speeding" cameras?
Does anyone have any experience with any product (sprays? covers?) that is effective against the automatic "speeding" cameras -- you know, the kind that take pictures of your license plate, then mail you the bill. Some, locally, are permanently mounted, others mobile and moved from area to area? Yes, yes.... I know.....don't speed. Let's just say this is scientific interest. I've seen ads for license plate sprays and covers.....but does anything really work?
There have been discussed the aerosol spray on polarized diffuser sprays to put over a license plate cover (EZ-Pass/Fast Pass toll camera use primarily), but I don't know how well they would work from an off angle photo speeding camera.
Most of the photo radar spots here are based on in-ground sensors, so no radar jammer etc will save you (except for the mobile ones, but I think they also use mobile ground sensors). The only hope is getting a liscence plate difuser that does not allow you to see the license plate when viewing from an angle greater than20-30 degrees. the problem is they are 'illegal' from some points of view because theoretically the liscence plate is not in clear view (it is, from straight on).
The only side note is that for the ticket to be 'legal' you have to be served from an officer of the court. that means when you get the ticket throw it in the garbage and deny ever getting it. Also, do not accept certified letters, and make sure everyone at home does not sign a receipt from a police officer in case they show up at home (they will usually come during business hours). If they do not serve you in ~6 months (200 days here in AZ) then thats it, your 'free'.
The other 'trick' is to register your car in your spouses name and vice versa. The ticket will come to the 'owner' of the car, and therefore the picture will not match the owner. The responsibility to find the 'correct' person is on them, and you do not have to tell them who was driving the car if they ask. They should have your drivers liscence picture on computer, so it is an easy denial.
Those sprays would work during the day as it relies on the flash to overexpose the plate. Would a good radar detector do the job? Also, I think they have to get a head shot of the driver. I am thinking of buying a amber or dark brown plexiglass that you can clip on the visor to avoid any red light or speeding cameras. Those are sold to reduce glare but should work against such things. The plate cover is good but easy to spot by a cop. There are some people that don't put the plate on their cars too.
I like Deven's devious owner/driver shuffle (post #3)...so they cannot establish beyond a reas. doubt who was driving.
Ironically, this was in yesterday's paper:
Page 3 of 3
Does that PhotoBlocker spray really work?
It didn't for one reader. A local psychologist, who was too embarrassed to let me print his name, sprayed five coats on his license plate, then zipped through the intersection at East 40th and Prospect. Click. $100.
A week after he paid the bill, the traffic camera caught him racing through the same intersection. Click. $100.
He admits he deserved the first ticket. He's appealing the second one.
He said PhotoBlocker said this has never happened before.
"I want them to cover at least one ticket," the speeder said.
How about just slowing down?
Page 3 of 3
I developed a countermeasure to this system that is fairly simple. The majority of these cameras require a flash to catch the plate information (obviously critical at night) but with a strobe unit located near the plate and a peanut slave the onboard flash can immediately fire ITS strobe when the state equipment fires and it will create a blind spot as the camera won't be able to handle such a bright return.
dan
dan
dan
dan
BTW, if they are sophisticated enough to read off their film plane, your approach wont work either. Well, maybe if it reads your stobe it will underexpose the plate. But it is much easier to fix underexposure than overexposure.
Cut a piece of laptop security screen filter the size of the license plate and install it under the plate rim, the plate won't be visible from an angle.
http://www.nextag.com/SONY-VGP-FL8-s...RE-PRICES-html
I like this idea except CA and most cities do not allow cover over plates. This will easily get a cop's attention.
Do you need front plate to get caught? Isn't the front plate required to get you on camera by law? If so, just pull of the camera.
I use a product called "Pig Away". It responds with a bright strobe light on detection of the camera taking my picture within 1/10,000th of a second hence blinding (temporarily) the camera.
For the rear of my car I use a product called "Greased Pig" which initiates an oil slick via the RMS cutoff valve (programmed into my Sport button).
So, maybe a nice clear front plate "safe" like the pieces offered by MacNeil (the WeatherTech ClearCover) with a good "matting" spray like Photobuster sprayed -inside- the clear acrylic cover...
Maybe we need to do some testing? As soon as I'm done staining the deck, maybe...
-don
