Anything effective against "speeding" cameras?
Originally Posted by allegretto
Bravo man! I like that. Another approach would be to aim the onboard strobe at you rplate. Now if the copcam reads off the film plane this wont work. But I suspect they use a rather simple fixed aperture/speed setting and you'll overexpose the hell out of the film..
BTW, if they are sophisticated enough to read off their film plane, your approach wont work either. Well, maybe if it reads your stobe it will underexpose the plate. But it is much easier to fix underexposure than overexposure.
those things use film?
how can overexposure be fixed?
you a photobug?
best,
jeff
Originally Posted by icon
herman,
you a photobug?
best,
jeff
you a photobug?
best,
jeff
As the Physicists here can tell us, there was recently a debate on whether or not even a Black Hole could destroy data. I believe that even Hawking thought it could, but in the end relented and agreed with the majority that even data drawn into a Black Hole could be preserved.
Ben...?
Poseur
Perhaps the XPL option with Porsche was what you should have selected:
XPL Reversing Plates 1485.00
First seen on an Aston Martin DB-5 around 1965.
Dan
Dan
digital overexposure leaves nothing to work with and can't be fixed.
However, if it has been recorded, it cannot be lost unless it is completely overwritten.
So you are correct. That's why I think you can cheat the photo radar by the strobe Dan spoke of.
Originally Posted by OCBen
It all depends on whose black ho we're talking about.....and what it is you're putting inside this black hole that you've oddly named "data."
BTW, Black Ho's in LA have been the downfall of several guys.
BTW, Black Ho's in LA have been the downfall of several guys. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The Penguin King
Originally Posted by wross996tt
Drive slower?
Did my statement above not register with anything you were aware of, or are you just playing with me?
My area of expertise is applied physics, the more mundane science that is used in designing spacecraft (currently) and launch systems (formerly - yes Jeff, rocket science
Originally Posted by Coochas
True, however both Hugh Grant and Eddie Murphy recovered nicely.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
![](http://samizdata.net/~pdeh/Elizabeth_Hurley_02.jpg)
The Penguin King
I was a physics major. In '76, our department had to rename a conference on black holes to "Are Gravitationally Collapsed Configurations Excitable". No joke.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
[QUOTE=OCBen]I don't dabble in theoretical astrophysics much - I find it rather boring and a waste of time, frankly. Arguments such as that often devolve into battles of opinions expressed by those who are supposedly in authority. And many try to win their arguments by the logical fallacy of appealing to authority, or more formally referred to as argumentum ad verecundiam. Such as by saying that if Stephen Hawking says it's so, then it must be so, without providing conclusive proof, which is very elusive in this realm.
) - the stuff you can touch and feel and make do what you want it to do, reliably and predictably - that's what I deal with.
Well, it depends if you consider losing Elizabeth Hurley nothing to cry over.![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
[/QUOTE)
I do understand your distaste. And your taste too for that matter. She is a Babe
And Coochas, remember what Eddie says,"the Bitch gets half".
Which in his case will be a LOT!!!
State of Texas requires you to display plates on front and back. Only a state trooper will pull you over for it, though. Local cops may write you up for it if they pull you over for something else. I've been given two tickets for it over the past five years on different cars. Good luck. I don't have one on the front of my 997S either.
